Hey guys,
i’m using ownCloud for a couple of month now and i’m pretty happy. Everything works fine and as expected, only the Logfile shows a lot of errors (though everything works perfectly fine, as i said).
So here’s the error message that repeats every couple seconds:
Debug carddav
Exception: {“Message”:“HTTP/1.1 401 No basic authentication headers were found”,“Exception”:“Sabre\DAV\Exception\NotAuthenticated”,“Code”:0,“Trace”:“#0 /www/htdocs/[my-hosting-username]/cloud/lib/private/connector/sabre/auth.php(157): Sabre\DAV\Auth\Backend\AbstractBasic->authenticate(Object(Sabre\DAV\Server), ‘ownCloud’)\n#1 /www/htdocs/[my-hosting-username]/cloud/lib/private/connector/sabre/auth.php(127): OC\Connector\Sabre\Auth->auth(Object(Sabre\DAV\Server), ‘ownCloud’)\n#2 /www/htdocs/[my-hosting-username]/cloud/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php(118): OC\Connector\Sabre\Auth->authenticate(Object(Sabre\DAV\Server), ‘ownCloud’)\n#3 [internal function]: Sabre\DAV\Auth\Plugin->beforeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#4 /www/htdocs/[my-hosting-username]/cloud/3rdparty/sabre/event/lib/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#5 /www/htdocs/[my-hosting-username]/cloud/3rdparty/sabre/dav/lib/DAV/Server.php(456): Sabre\Event\EventEmitter->emit(‘beforeMethod’, Array)\n#6 /www/htdocs/[my-hosting-username]/cloud/3rdparty/sabre/dav/lib/DAV/Server.php(254): Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#7 /www/htdocs/[my-hosting-username]/cloud/apps/contacts/appinfo/remote.php(84): Sabre\DAV\Server->exec()\n#8 /www/htdocs/[my-hosting-username]/cloud/remote.php(137): require_once(‘/www/htdocs/w00…’)\n#9 {main}”,“File”:“/www/htdocs/[my-hosting-username]/cloud/3rdparty/sabre/dav/lib/DAV/Auth/Backend/AbstractBasic.php”,“Line”:70}
This is a problem since the log file gets very big …
Database: mysql 5.6.30
PHP version: 5.6.23
ownCloud version (see ownCloud admin page): 8.2.7
