- Try to login with correct password.
Login accepted.
The login is not accepted but there is no error message “Wrong password. Reset it?” unless I actually do mistype the password. So I know that my password is correct.
Operating system: Debian GNU/Linux 9.0
Web server: Apache 2.4.25
Database: MySQL MariaDB 15.1
PHP version: 7.0.30
ownCloud version: 10.1.1
Where did you install ownCloud from: Debian package
Signing status (ownCloud 9.0 and above): Cannot log in to get this.
"system": {
"instanceid": "oc1e0d67c158",
"trusted_domains": [
"www.malcolm.id.au"
"3rdpartyroot": "\/var\/www\/owncloud\/",
"3rdpartyurl": "\/3rdparty",
"dbtype": "mysql",
"version": "10.1.1.1",
"dbname": "owncloud",
"dbhost": "localhost",
"dbtableprefix": "oc_",
"installed": true,
"forcessl": true,
"mail_smtpmode": "php",
"app.mail.imaplog.enabled": true,
"app.mail.server-side-cache.enabled": true,
"app.mail.transport": "php-mail",
"preview_libreoffice_path": "\/usr\/bin\/soffice",
"theme": "",
"maintenance": false,
"overwritewebroot": "\/owncloud",
"overwrite.cli.url": "\/owncloud",
"logfile": "\/var\/log\/owncloud.log",
"loglevel": "2",
"trashbin_retention_obligation": "auto",
"updatechecker": false
Enabled:
- activity: 2.4.2
- calendar: 1.6.2
- comments: 0.3.0
- configreport: 0.1.2
- contacts: 1.5.5
- dav: 0.4.0
- federatedfilesharing: 0.3.1
- federation: 0.1.0
- files: 1.5.2
- files_external: 0.7.1
- files_pdfviewer: 0.11.0
- files_sharing: 0.11.0
- files_texteditor: 2.3.0
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- files_videoplayer: 0.9.9
- firstrunwizard: 1.1.1
- gallery: 16.1.1
- market: 0.4.0
- music: 0.9.5
- notifications: 0.4.1
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- templateeditor: 0.4.0
- updatenotification: 0.2.1
Disabled:
- encryption
- external
- rainloop
- tasks
- user_external
Are you using encryption: No
Browser: Chrome
Operating system: Mac OS
Nothing relevant.
{"reqId":"NCpIcsbKYtcdpDlJGws9","level":2,"time":"2019-05-10T18:23:49+00:00","remoteAddr":"192.168.42.123","user":"terminus","app":"core","method":"GET","url":"\/owncloud\/index.php\/apps\/files\/","message":"Login failed: 'terminus' (Remote IP: '192.168.42.123')"}
{"reqId":"NCpIcsbKYtcdpDlJGws9","level":2,"time":"2019-05-10T18:23:50+00:00","remoteAddr":"192.168.42.123","user":"--","app":"core","method":"GET","url":"\/owncloud\/index.php\/apps\/files\/","message":"Login failed: 'terminus' (Remote IP: '192.168.42.123')"}
Nothing relevant.
