- Try to login via my domain
https://xxx.synology.me/owncloud
- Try to login via local ip
https://192.168.188.57/owncloud
Both methods of login work fine.
I can only login via the local ip address. When I try to login via my domain nothing happens and I get redirected back to the same site. The only difference is the URL:
https://xxx.synology.me/owncloud/index.php/login?user=abc&redirect_url=%252Fowncloud%252Findex.php%252Fapps%252Ffiles%252F
Operating system: Synology DSM 6.2.3-25426 Update 3
Web server: nginx
Database: MariaDB 10
PHP version: 7.3
ownCloud version: 10.6.0
Where did you install ownCloud from: https://owncloud.com/download-server/
https://192.168.188.57/owncloud/index.php/settings/integrity/failed
https://pastebin.com/zHDHSd5U
It’s a fresh installation so I didn’t activate any apps by myself.
Are you using encryption: no
Browser: Firefox
Operating system: Windows 10
https://pastebin.com/uBFCR2M6
