Hello ownCloud Community,
I’m trying to update from an older ownCloud instance (10.0.8.5) to the latest one. However, I cannot log in at all. To find out what the problem is, I set up a fresh ownCloud instance (10.0.10.4) that is quite close to the one I use.
I hope, someone can help me. I don’t know what i can do so that it work.
Please help me.
Best greetings
Steffen
However, it is not possible to log in here either. I get the following error messages when I activate the debug log level:
- clean Install ownCloud 10.0.1.4 with PHP7.2
- clean Install ownCloud 10.9. with PHP7.4
It should be possible to login
The Login is not possible.
Provider: Alfahosting
Operating system: Ubuntu 20.04 LTS
Web server: Apache
PHP version: 7.2
ownCloud version: 10.0.1.4
fresh install
about the Browser with the zip image.
it is not possible
<?php
$CONFIG = array(
'instanceid' => 'ocm0bjx1iexr',
'passwordsalt' => 'NgBif7Pkjnl7ZO2aKi2tkJw1PUUsf2',
'secret' => '5LGEWLVcoRbGgKGyNL2gSmWQp9SNuRgstUYakHUh3dsywY6l',
'trusted_domains' =>
array(
0 => 'cloud.dvl-sachsen.de',
'datadirectory' => '/var/www/vhosts/domain.de/subdomain/owncloud_10.0.10/data',
'overwrite.cli.url' => 'https://subdomain.domain.de/owncloud_10.0.10',
'dbtype' => 'mysql',
'version' => '10.0.10.4',
'dbname' => 'myDatebase',
'dbhost' => 'localhost:3306',
'dbtableprefix' => 'oc_',
'dbuser' => 'myDbUser',
'dbpassword' => myPassword',
'logtimezone' => 'UTC',
'installed' => true,
'loglevel' => 0,
i can’t start the occ comand, it should be activ only the standard apps
Are you using external storage, if yes which one:
no
Are you using encryption:
no
Are you using an external user-backend, if yes which one:
no
Firefox, Chrome
macOS 12.3.1
[Wed Apr 27 08:28:41.421669 2022] [auth_basic:error] [pid 19287:tid 140052599703296] [client 91.0.0.0:49838] AH01617: user MyLogin: authentication failure for "/owncloud/index.php/heartbeat": Password Mismatch
[Wed Apr 27 08:29:23.536905 2022] [fcgid:warn] [pid 19287:tid 140052658452224] [client 91.0.0.0:49846] mod_fcgid: stderr: PHP Fatal error: Uncaught Error: Call to a member function getLogger() on null in /var/www/vhosts/domain.de/subdomain/owncloud_10.0.10/index.php:86
[Wed Apr 27 08:29:23.536964 2022] [fcgid:warn] [pid 19287:tid 140052658452224] [client 91.0.0.0:49846] mod_fcgid: stderr: Stack trace:
[Wed Apr 27 08:29:23.536976 2022] [fcgid:warn] [pid 19287:tid 140052658452224] [client 91.0.0.0:49846] mod_fcgid: stderr: #0 {main}
webserver log here
91.0.0.0 - MyLogin [27/Apr/2022:09:26:36 +0000] "GET /owncloud_10.0.10/index.php/login?redirect_url=%252Fowncloud_10.0.10%252Findex.php%252Fapps%252Ffiles%252F HTTP/1.1" 200 3587 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/vendor/select2/select2.css?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 3869 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/css/header.css?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 2974 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/css/styles.css?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 7139 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/css/icons.css?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 2709 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/css/fonts.css?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 1446 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/css/global.css?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 1068 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/css/apps.css?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 4741 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/css/inputs.css?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 3208 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/css/fixes.css?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 855 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/css/multiselect.css?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 1520 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/css/mobile.css?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 1688 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/css/jquery-ui-fixes.css?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 1384 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/vendor/jquery-ui/themes/base/jquery-ui.css?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 6600 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/css/tooltip.css?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 1285 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/css/share.css?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 2354 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/apps/files_versions/css/versions.css?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 1078 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/apps/files_videoplayer/css/style.css?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 2465 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/apps/firstrunwizard/css/colorbox.css?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 1365 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/css/jquery.ocdialog.css?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 1596 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/apps/firstrunwizard/css/firstrunwizard.css?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 920 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/vendor/jquery/dist/jquery.min.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 30266 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/vendor/jquery-migrate/jquery-migrate.min.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 4527 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/vendor/underscore/underscore.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 15496 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/vendor/moment/min/moment-with-locales.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 73537 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/vendor/jquery-ui/ui/jquery-ui.custom.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 107370 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/vendor/handlebars/handlebars.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 36304 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/vendor/blueimp-md5/js/md5.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 3429 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/vendor/bootstrap/js/tooltip.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 5003 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/vendor/backbone/backbone.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 20765 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/vendor/es6-promise/dist/es6-promise.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 7415 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/vendor/davclient.js/lib/client.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 4002 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/vendor/clipboard/dist/clipboard.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 6012 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/js/jquery.ocdialog.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 2025 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/index.php/core/js/oc.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 3799 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/js/l10n.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 3098 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/vendor/bowser/src/bowser.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 5080 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/js/js.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 18363 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/l10n/de.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 12145 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/js/oc-dialogs.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 7697 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/js/octemplate.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 2003 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/js/eventsource.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 2336 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/search/js/search.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 4034 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/js/oc-requesttoken.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 765 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/js/apps.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 1680 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/js/config.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 1162 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/js/mimetypelist.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 1614 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/vendor/snapjs/dist/latest/snap.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 6534 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/js/mimetype.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 1919 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/js/oc-backbone.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 801 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/js/oc-backbone-webdav.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 4768 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/vendor/select2/select2.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 34157 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/js/jquery.avatar.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 2368 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/js/backgroundjobs.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 1183 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/js/placeholder.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 2617 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/js/sharescollection.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 975 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/js/sharemodel.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 1743 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/js/shareitemmodel.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 5199 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/js/sharedialoglinklistview.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 3364 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/js/sharedialoglinkshareview.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 4202 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/js/sharedialogresharerinfoview.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 1645 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/js/shareconfigmodel.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 1449 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/js/sharedialogmailview.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 3231 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/js/sharedialoglinksocialview.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 1761 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/js/sharedialogshareelistview.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 3719 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/js/sharedialogview.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 4985 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/js/sharedialogexpirationview.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 2602 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/js/share.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 5398 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/apps/firstrunwizard/l10n/de.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 1488 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/apps/files_videoplayer/js/viewer.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 1794 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/js/files/fileinfo.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 1446 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/apps/firstrunwizard/js/firstrunwizard.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 862 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/apps/firstrunwizard/js/jquery.colorbox.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 9496 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/js/files/client.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 6223 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/vendor/jsTimezoneDetect/jstz.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 4523 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/js/visitortimezone.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 869 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/js/lostpassword.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 1895 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/js/login.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 1096 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/js/browser-update.js?v=9f1e52b9f5b86563d7cf0c3db888cecd HTTP/1.1" 200 1108 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/img/background.jpg HTTP/1.1" 200 156938 "https://cloud.dvl-sachsen.de/owncloud_10.0.10/core/css/styles.css?v=9f1e52b9f5b86563d7cf0c3db888cecd" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/img/logo.svg HTTP/1.1" 200 9390 "https://cloud.dvl-sachsen.de/owncloud_10.0.10/core/css/header.css?v=9f1e52b9f5b86563d7cf0c3db888cecd" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/img/loading-dark.gif HTTP/1.1" 200 2837 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/img/actions/confirm.svg HTTP/1.1" 200 872 "https://cloud.dvl-sachsen.de/owncloud_10.0.10/core/css/icons.css?v=9f1e52b9f5b86563d7cf0c3db888cecd" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/fonts/OpenSans-Light.woff HTTP/1.1" 200 63464 "https://cloud.dvl-sachsen.de/owncloud_10.0.10/core/css/fonts.css?v=9f1e52b9f5b86563d7cf0c3db888cecd" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/vendor/browser-update/browser-update.js?_=1651051597408 HTTP/1.1" 200 11511 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/cron.php HTTP/1.1" 200 798 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/img/favicon-touch.png HTTP/1.1" 200 4152 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
91.0.0.0 - MyLogin [27/Apr/2022:09:26:37 +0000] "GET /owncloud_10.0.10/core/img/favicon.ico HTTP/1.1" 200 5495 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0"
{"reqId":"Ymj-69XyAEvg7tZrst6eegAAAAE","level":0,"time":"2022-04-27T08:33:48+00:00","remoteAddr":"91.0.0.0","user":"MyLogin","app":"OC\\Authentication\\Token\\DefaultTokenProvider::getToken","method":"POST","url":"\/owncloud_10.0.10\/index.php\/login","message":"token 75d022aeae314f0b9203f62b69fa2c210dd6d5b831a4e13b1a29cf03395c5b5408e349691b824853f07ff4f4a21efe5d3f7a6f4a7e77c92bbe3f5a5c72f92941 does not exist"}
{"reqId":"Ymj-69XyAEvg7tZrst6eegAAAAE","level":0,"time":"2022-04-27T08:33:48+00:00","remoteAddr":"91.0.0.0","user":"MyLogin","app":"OC\\Authentication\\Token\\DefaultTokenProvider::generateToken","method":"POST","url":"\/owncloud_10.0.10\/index.php\/login","message":"generating token b9912663a6d73c63fdd004236faa1ac9baeb68817148bbbf3d82dbcfefcc31dcf43d5d024793f5a80c00da03ce1c02628c9385951f9a6506c42814497eceec6b, uid MyLogin, loginName MyLogin, pwd set, name Mozilla\/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit\/537.36 (KHTML, like Gecko) Chrome\/100.0.4896.127 Safari\/537.36, type temporary"}
{"reqId":"Ymj-7NXyAEvg7tZrst6eewAAAAM","level":0,"time":"2022-04-27T08:33:48+00:00","remoteAddr":"91.0.0.0","user":"MyLogin","app":"OC\\User\\Session::validateToken","method":"GET","url":"\/owncloud_10.0.10\/index.php\/apps\/files\/","message":"token b9912663a6d73c63fdd004236faa1ac9baeb68817148bbbf3d82dbcfefcc31dcf43d5d024793f5a80c00da03ce1c02628c9385951f9a6506c42814497eceec6b with token id 3 found, validating"}
{"reqId":"Ymj-7NXyAEvg7tZrst6eewAAAAM","level":0,"time":"2022-04-27T08:33:48+00:00","remoteAddr":"91.0.0.0","user":"MyLogin","app":"OC\\Authentication\\Token\\DefaultTokenProvider::getToken","method":"GET","url":"\/owncloud_10.0.10\/index.php\/apps\/files\/","message":"token 2a896663d301cd213980476c00ff121386efd6daad44735474eb91ca77076e3cadedb79654bb608b7044dd560eeea94faf0b6f3f6ccdf28cfdeaa57b8bf6a177 does not exist"}
{"reqId":"Ymj-7NXyAEvg7tZrst6eewAAAAM","level":2,"time":"2022-04-27T08:33:48+00:00","remoteAddr":"91.0.0.0","user":"MyLogin","app":"core","method":"GET","url":"\/owncloud_10.0.10\/index.php\/apps\/files\/","message":"Login failed: 'MyLogin' (Remote IP: '91.0.0.0')"}
{"reqId":"Ymj-7NXyAEvg7tZrst6eewAAAAM","level":0,"time":"2022-04-27T08:33:48+00:00","remoteAddr":"91.0.0.0","user":"MyLogin","app":"OC\\User\\BasicAuthModule::auth","method":"GET","url":"\/owncloud_10.0.10\/index.php\/apps\/files\/","message":"Invalid password for username MyLogin, trying as email."}
{"reqId":"Ymj-7NXyAEvg7tZrst6eewAAAAM","level":0,"time":"2022-04-27T08:33:48+00:00","remoteAddr":"91.0.0.0","user":"MyLogin","app":"OC\\Authentication\\Token\\DefaultTokenProvider::invalidateToken","method":"GET","url":"\/owncloud_10.0.10\/index.php\/apps\/files\/","message":"invalidating token b9912663a6d73c63fdd004236faa1ac9baeb68817148bbbf3d82dbcfefcc31dcf43d5d024793f5a80c00da03ce1c02628c9385951f9a6506c42814497eceec6b"}
{"reqId":"Ymj-7NXyAEvg7tZrst6eewAAAAM","level":0,"time":"2022-04-27T08:33:48+00:00","remoteAddr":"91.0.0.0","user":"--","app":"OC\\Authentication\\Token\\DefaultTokenProvider::getToken","method":"GET","url":"\/owncloud_10.0.10\/index.php\/apps\/files\/","message":"token b9912663a6d73c63fdd004236faa1ac9baeb68817148bbbf3d82dbcfefcc31dcf43d5d024793f5a80c00da03ce1c02628c9385951f9a6506c42814497eceec6b does not exist"}
{"reqId":"Ymj-7NXyAEvg7tZrst6eewAAAAM","level":0,"time":"2022-04-27T08:33:48+00:00","remoteAddr":"91.0.0.0","user":"--","app":"OC\\Authentication\\Token\\DefaultTokenProvider::getToken","method":"GET","url":"\/owncloud_10.0.10\/index.php\/apps\/files\/","message":"token 2a896663d301cd213980476c00ff121386efd6daad44735474eb91ca77076e3cadedb79654bb608b7044dd560eeea94faf0b6f3f6ccdf28cfdeaa57b8bf6a177 does not exist"}
{"reqId":"Ymj-7NXyAEvg7tZrst6eewAAAAM","level":0,"time":"2022-04-27T08:33:48+00:00","remoteAddr":"91.0.0.0","user":"--","app":"OC\\User\\Session::login","method":"GET","url":"\/owncloud_10.0.10\/index.php\/apps\/files\/","message":"regenerating session id for uid MyLogin, password set"}
{"reqId":"Ymj-7NXyAEvg7tZrst6eewAAAAM","level":0,"time":"2022-04-27T08:33:48+00:00","remoteAddr":"91.0.0.0","user":"--","app":"OC\\User\\Session::validateToken","method":"GET","url":"\/owncloud_10.0.10\/index.php\/apps\/files\/","message":"token 2a896663d301cd213980476c00ff121386efd6daad44735474eb91ca77076e3cadedb79654bb608b7044dd560eeea94faf0b6f3f6ccdf28cfdeaa57b8bf6a177, not found"}
{"reqId":"Ymj-7NXyAEvg7tZrst6eewAAAAM","level":2,"time":"2022-04-27T08:33:48+00:00","remoteAddr":"91.0.0.0","user":"--","app":"core","method":"GET","url":"\/owncloud_10.0.10\/index.php\/apps\/files\/","message":"Login failed: 'MyLogin' (Remote IP: '91.0.0.0')"}
{"reqId":"Ymj-7NXyAEvg7tZrst6eewAAAAM","level":0,"time":"2022-04-27T08:33:48+00:00","remoteAddr":"91.0.0.0","user":"--","app":"no app in context","method":"GET","url":"\/owncloud_10.0.10\/index.php\/apps\/files\/","message":"Current user is not logged in"}
{"reqId":"Ymj-7NXyAEvg7tZrst6efgAAAAk","level":0,"time":"2022-04-27T08:33:48+00:00","remoteAddr":"91.0.0.0","user":"--","app":"cron","method":"GET","url":"\/owncloud_10.0.10\/cron.php","message":"Started background job of class : OCA\\Files_Trashbin\\BackgroundJob\\ExpireTrash with arguments : "}
{"reqId":"Ymj-7NXyAEvg7tZrst6efgAAAAk","level":0,"time":"2022-04-27T08:33:48+00:00","remoteAddr":"91.0.0.0","user":"--","app":"cron","method":"GET","url":"\/owncloud_10.0.10\/cron.php","message":"Finished background job, the job took : 0 seconds, this job is an instance of class : OCA\\Files_Trashbin\\BackgroundJob\\ExpireTrash with arguments : "}
JQMIGRATE: Migrate is installed, version 1.4.0 jquery-migrate.min.js:2:552
Layout-Darstellung wurde erzwungen, bevor die Seite vollständig geladen war. Falls Stylesheet noch nicht geladen sind, kann dies zu einem kurzzeitigen Darstellung des Inhalts ohne Formatierung führen. jquery.min.js:4:18306
Deprecation warning: tipsy is deprecated. Use tooltip instead. js.js:2296:10
Source-Map-Fehler: Error: request failed with status 401
Ressourcen-Adresse: https://cloud.dvl-sachsen.de/owncloud_10.0.10/core/vendor/jquery/dist/jquery.min.js?v=9f1e52b9f5b86563d7cf0c3db888cecd
Source-Map-Adresse: jquery.min.map
