Logs flooded with 404 error for .../users/<alphanum>/received.json
My logs are flooded with this message:
{"level":"warn","service":"storage-system","pkg":"rhttp","traceid":"7a3af4fbc09bc9deb5a72b5fbf5795c5","host":"127.0.0.1","method":"GET","uri":"/data/spaces/jsoncs3-share-manager-metadata%21jsoncs3-share-manager-metadata/users/<redacted_alphanumerical>/received.json","url":"/users/<redacted_alphanumerical>/received.json","proto":"HTTP/1.1","status":404,"size":0,"start":"31/Oct/2025:14:04:50 +0000","end":"31/Oct/2025:14:04:50 +0000","time_ns":404774,"time":"2025-10-31T14:04:50Z","message":"http"}
I have OCIS running in a container with Authelia authentication with LLDAP backend. OCIS’ own IDP is disabled.
No other errors perceived. From an end user point of view, everything works.
Anyone else has this problem or is this only me?
Does anybody has an idea on where to start looking for the error?
Mmh. That’s strange. Is it always the same alphanum that you see in the logs or is it different ones?
The received.json holds the shares that a specific user did receive. If this isn’t found the user didn’t get any shares yet.
But I’m wondering:
  1. Why do you see so many logs
and
  1. Why all of them are printed as warning.
Do you do something specific when seeing this error messages? Do you have a lot of users in your IDP?
It is always the same alhpanum.
For my IDP: I disabled the internal IDP. and rely completely on Authelia and LLDAP. I only have 4 users and some of them aren’t even “enabled” in OCIS (they haven’t logged on ever yet). So it might be easy to match the id with a user but I wouldn’t know how.
That said, the only error I see is that the logs are flooded. I have access to the shares and everything seems to work.
@bertmelis I would assume you have a desktop client running syncing your data?
The log is being written because something (I assume desktop client) is polling your shares. Since nobody ever shared a file with you you don’t have a received.json - hence the error message.
Possible mitigations:
  1. Ignore it - it does no harm
  2. Raise log levels so it doesnt get logged any more.
  3. Have someone share a file/folder with you. This will create the received.json and get rid of the error message.
We will check what we can do from code side to avoid these unnecessary logs.
