Hi all,
I encounter heavy traffic load on my server, issued by CalDAV/CardDAV sync from one specific Mac.
- Client macOS 11.6.1 BigSur
- macOS Addressbook and Calendar Apps connected via CalDAV/CardDAV with owncloud for syncing
Sync should run smoothly without causing heavy server loads
about 200 MB of traffic daily just for Card-/CalDAV syncs which exceeds serverlimits
Operating system: Debian 10
Web server: Apache
Database: 10.3.31-MariaDB
PHP version: 7.4.25
ownCloud version: (see ownCloud admin page) 10.8.0
updated
zip-file
- Admin Config Report
- Deleted Files
- Share Files
- Update Notification
- Versions
- Activity
- Calendar
- Collaborative Tags
- Comments
- Contacts
- First Run Wizard
- Gallery
- Impersonate
- Market
- Media Viewer
- Notifications
- PDF Viewer
- Text Editor
none
no
none
CardDAV, CalDAV build in
macOS 11.6.1 BigSur
tons of entries like:
PROPFIND /remote.php/dav/addressbooks/users/xx/contacts/
all attached to
macOS/11.6 (20G165) AddressBookCore/2452.7
(meanwhile updated to 11.6.1 - no change)
Thanks for any advice
regards Stefan
