I have a strange behaviour with my Owclound Desktop Client on MacOS
I can not open settings in Ow-client. Usually I can open settings and see current sync state, configre account and so on. On my system this does not work. I can choose with a right-click omn the OC icon to “open” but nothing happens.
The sync itself is running fine, it uploads new files to my server. Work as expected. I just can not open the app windows itself.
The process is running:
user@mac MacOS % ps ax | grep owncloud
1310 ?? S 0:00.97 /Applications/owncloud.app/Contents/MacOS/owncloud
1313 ?? Ss 0:00.06 /Applications/owncloud.app/Contents/PlugIns/FinderSyncExt.appex/Contents/MacOS/FinderSyncExt -AppleLanguages ("de-DE")
1318 s000 R+ 0:00.00 grep owncloud
I can end the app by command line:
user@mac MacOS % ./owncloud -q
sync.utility: migrateLaunchOnStartup: has launch agent plist: true has deprecated launch on startup: false
gui.application: Already running, exiting...
1313 ?? Ss 0:00.08 /Applications/owncloud.app/Contents/PlugIns/FinderSyncExt.appex/Contents/MacOS/FinderSyncExt -AppleLanguages ("de-DE")
1325 s000 R+ 0:00.00 grep owncloud
On the desktop there is no option to quit/ end the OC client. I can just select to open it, but nothing happens.
I can, however manually kill the instance through console:
chvoelker@cvoelker MacOS % ./owncloud -q
But when started with the -s parameter the settings page opens fine:
user@mac MacOS % ./owncloud -s
My Mac is a MacBook Pro (2012) with M1 cpu and running on macOS Venture 13.1.
Anyone having a clue?
Thanks!
/KNEBB
