- Create New User
- Email is sent to new user to access own cloud
3.Mail is received and html code is interpreted correctly by email client - User goes to the link and provides new password
- An email is sent to the user regarding “Password change successfully”
- The whole body of the message is presented in plain text (all html statements are shown)
IF THE USER REQUESTS A PASSWORD RESET FOR A SECOND TIME, THE MAIL IS SENT CORRECTLY
The Password change message should be displayed correctly (html interpreted, not displayed)
Message is presented as plain text
Centos 7
Apache 2.4
MariaDB (Mysql)
10.2
Fresh Install
Community Site
JSON File: [https://docustore.tratoregio.com/index.php/s/JwXlP8GV7oADBic](http://REPORT.json)
NO
YES
NO
N/A
Safari
Mojave
NO ACTIVITY DURING THE TEST
THERE IS NO ACTIVITY DURING THE PROCESS
#### Browser log
c) …
