Maintenance and update market place
Hi! first of all I have to say that I have not too much idea of how my server works, but I have a problem and would like to solve it.
Yesterday I updated my owncloud server from an older version to one of 9 versions, then everything worked fine. I did it using the updater included in configuration.
Later I tried to update it to 10 but was impossible. Got messages saying that was not impossible to update various marketplace Apps and later it was settled automaticly under maintenance.
As I told you, have not much idea about how it works and would like to know if possible:
  1. Go to latest 9 version throught a backup generated during the update progress
  2. Solve this problem with 10 version an continue
I have read a lot of it and most of the times you say that can be solve by executing the console OCC and typing some code. The problem is that I have no idea of how to do it.
I have installed owncloud by myself following the site steps and everything was fine even when it was updated, but now I found that problem.
Thank you in advance for your help!
The problem might be, that the old marketplace no longer exists. You have to configure your v9 to the new marketplace. To do so, add the following line to your config.php.
‘appstoreurl’ => ‘https://marketplace.owncloud.com/api/v0’,
And maybe you’ll have to disable some apps before updating.
