Maintenance mode and Could not open input file: occ
Hi. Help pls.
After the update owncloud on the univention server i got message:
This ownCloud instance is currently in maintenance mode, which may take a while.
root@ucs:~# cd /var/www/owncloud
root@ucs:/var/www/owncloud# sudo -u www-data php occ maintenance:mode --off
http://joxi.ru/12MDXPwfM5xPbm.jpg
Maybe this is the directory of the old version of owncloud? I can not find where else config files can be.
http://joxi.ru/GrqL3nRSQZJv1A.jpg
:cold_sweat:
try with ./occ instead of occ
