I received a notification in my client that “Update for ownCloud core to version 10.3.0 is available.” But when I attempt to upgrade via docker-compose, I get error “manifest for owncloud/server:10.3.0 not found”. Checking hub.docker.com confirms that the latest owncloud/server image does not have a tag of 10.3.0.
So I will rollback to 10.2.1 I guess, and ignore the update notice until there’s a docker image tagged 10.3.0.
- put in maintenance mode;
- docker-compose down
- edit .env to OWNCLOUD_VERSION=10.3.0
- docker-compose up -d
New image 10.3.0 should download and run
error: manifest for owncloud/server:10.3.0 not found
Operating system: debian
ownCloud version: 10.2.1
Updated from an older ownCloud or fresh install: attempted update
