- Enable Manual File Locking App
- Lock one file using LDAP user
- Try editing the document (using OnlyOffice or download/upload a file or edit the file over desktop client)
I’ve tried this with 3 different ownCloud servers (all different versions), all connecting to different LDAP server as well with 3 different OnlyOffice Docs servers (also different version). I get this error in all cases.
LDAP user who locks the file should be able to edit it. This functionality works fine with local owncloud user, but not with LDAP users.
If you open a document in OnlyOffice, it is opened in read-only mode.
If you try to download, edit and then upload the file again, it says the file is locked.
No user can edit the locked file. Not even the LDAP user who locked it.
Ubuntu 20.04 LTS
Apache
MariDB
Tried on different ownCloud version with also different OnlyOffice versions
10.7 - 10.9
fresh install
