None of the topics seem to be matching nor even close to my question therefore I am hoping for some help here. I am using a Cloud Based Self hosted Server. Running VB and Owncloud Server, my question is I have a network that also has several NAS Boxes on it. I want to map my Cloud Server to those NAS Boxes.
I know SMB can be used however it seems unstable so my question is would it simply be better for me to simply get additional SAS Drives for the Server Internally and skip the attempt to map out NAS Boxes instead?
