Markdown editor?
In this request, a Markdown editor is mentioned. I could not find it… Am I too stupid to find it, or is it no longer available?
I need to display larger md files and release them for collaboration. The files are created with qownnotes. The text and the notes editor seem not to do that; nextcloud seems to have it.
Cheers,
Wolf
the post you linked is 3 years old, a lot can happen in 3 years :slight_smile:
The markdown app is no longer an ownCloud app.
Best Regards
Dmitry
Here is an ownCloud app that supports markdown
https://marketplace.owncloud.com/apps/notes
I have tried it and it works great :slight_smile:
Best Regards
Dmitry
Thank you - I’m having this one active for years. But it does not really what I want:
  • I cannot publish md files for other people who are not in the same OC
  • I do not see paragraph formats - they all look the same
  • I only see top few lines, not the whole doc. There is a (…) icon at the bottom of the doc, which suggest I could load more, but that’s not functional
So I may have to look for another solution.
Cheers,
Wolf
