- Upgrade from 9.0.0 to 9.1 to 10.0.2.1.
- Try to load the Market index.php/apps/market/#/
The market should load.
The loading icon just spins.
Ubuntu 14.04
Apache 2.4
Mysql 5.6
10.0.2.1
Updated from 9.0.0 to 9.1 to 10.
Original 9.0 was from git. Upgraded to 9.1 and 10 tarballs.
"system": {
"installed": true,
"dbtype": "mysql",
"dbname": "owncloud",
"dbhost": "dbhostip",
"dbtableprefix": "oc_",
"forcessl": true,
"blacklisted_files": [],
"overwritehost": "",
"overwriteprotocol": "",
"overwritewebroot": "",
"overwritecondaddr": "",
"theme": "lane",
"default_language": "en",
"3rdpartyroot": "",
"3rdpartyurl": "",
"defaultapp": "files",
"knowledgebaseenabled": true,
"knowledgebaseurl": "http:\/\/api.apps.owncloud.com\/v1",
"appstoreurl": "http:\/\/api.apps.owncloud.com\/v1",
"mail_smtpdebug": false,
"mail_smtpmode": "php",
"mail_smtphost": "127.0.0.1",
"mail_smtpport": "25",
"mail_smtptimeout": 10,
"mail_smtpauthtype": "LOGIN",
"trashbin_retention_obligation": "180, auto",
"allow_user_to_change_display_name": true,
"appcodechecker": "",
"updatechecker": true,
"log_type": "syslog",
"logfile": "",
"loglevel": 0,
"remember_login_cookie_lifetime": 1296000,
"session_lifetime": 86400,
"custom_csp_policy": "default-src 'self'; script-src 'self' 'unsafe-eval'; style-src 'self' 'unsafe-inline'; frame-src *; img-src *; font-src 'self' data:; media-src *",
"xframe_restriction": true,
"datadirectory": "\/path\/to\/data\/test",
"maintenance": false,
"apps_paths": [
"url": "\/apps",
"writable": true
"customclient_desktop": "http:\/\/owncloud.org\/sync-clients\/",
"customclient_android": "https:\/\/play.google.com\/store\/apps\/details?id=com.owncloud.android",
"customclient_ios": "https:\/\/itunes.apple.com\/us\/app\/owncloud\/id543672169?mt=8",
"logdateformat": "F d, Y H:i:s",
"instanceid": "525f0e87378ff",
"version": "10.0.2.1",
"trusted_domains": [
"testowncloud.lanecc.edu"
"memcache.local": "\\OC\\Memcache\\Redis",
"redis": {
"host": "localhost",
"port": 6379,
"timeout": 0
"filelocking.enabled": "true",
"memcache.locking": "\\OC\\Memcache\\Redis"
Enabled:
- comments: 0.3.0
- configreport: 0.1.1
- dav: 0.2.9
- federatedfilesharing: 0.3.0
- federation: 0.1.0
- files: 1.5.1
- files_external: 0.7.0
- files_pdfviewer: 0.8.2
- files_sharing: 0.10.0
- files_texteditor: 2.2
- files_trashbin: 0.9.0
- files_versions: 1.3.0
- files_videoplayer: 0.9.8
- firstrunwizard: 1.1
- gallery: 16.0.2
- market: 0.1.0
- notifications: 0.3.0
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- templateeditor: 0.1
- updatenotification: 0.2.1
- user_ldap: 0.9.1
Disabled:
- encryption
- external
- files_antivirus
- theme-example
- user_external
No
No
LDAP, Novell eDirectory
N/A
Firefox
Ubuntu 16.04
N/A
Aug 31 11:19:04 testowncloud ownCloud[25901]: {PHP} array_map(): Argument #2 should be an array at /var/www/owncloud/apps/market/lib/Controller/MarketController.php#165
