Mass Folder Add
I had to import a lot of users and assign some default settings to them so I created a query to insert it into the db and it worked fine. Now I have to create default folders for users but going to make a query to add these, it does not work, can someone help me?
P.S.: Not sure if that’s the right section here. If not, please move it.
Please don’t make duplicate posts.
If someone has an answer you will be helped.
