MFA requirements for admin accounts
We are using the 10.5 stable version. The question is simple: can we enable MFA with DUO on the admin accounts only? It is a security recommendation originating from our cybersecurity review.
Thanks in advance for your assistance
Not sure if that was you posting on the DUO apps GitHub issue tracker, but there is already an issue about this:
So I doubt it is currently possible, and the developer hasn’t been active for quite some time in this repo.
Additionally, the only fork on GitHub, is also not active.
I’m not sure if there are any further settings with which you could achieve this on the DUO end.
If I had to implement MFA for a specific user group, I would use an IdP which supports it, e.g keycloak.
But that is not
