1.n/a
2.n/a
3.n/a
Tell us what should happen : Migrate existing ownCloud 7.0.4 to 10.0.7
Tell us what happens instead: N/A
Operating system: old server:- CentOS 7.0, new server RHEL 7
Web server: old version: Apache 2.4.6
Database: : MySQL 15.1
PHP version: : 5.4.16
ownCloud version: (see ownCloud admin page) : ownCloud 7.0.4
Updated from an older ownCloud or fresh install: Need to migrate to latest version
Where did you install ownCloud from: Need to know is direct path migration possible
Signing status (ownCloud 9.0 and above): ownCloud 7.0.4
Are you using external storage, if yes which one: local/smb/sftp/...
Are you using an external user-backend, if yes which one: LDAP/ActiveDirectory/Webdav/...
