Owncloud can be installed on Ubuntu 22.10
Installation not possible due to missing libico70 → current version on ubuntu 22.10 is libicu71
ownCloud version:
Client version:
Operating system: Ubuntu 22.10 (on wayland)
OS language:
Package: owncloud-client
Version: 2.11.1+oc-8438
Depends: libc6 (>= 2.34), libsqlite3-0 (>= 3.12.0), libstdc++6 (>= 11), ocqt51210-libqt5core5a, ocqt51210-libqt5dbus5, ocqt51210-libqt5gui5, ocqt51210-libqt5keychain1, ocqt51210-libqt5network5, ocqt51210-libqt5widgets5, ocqt51210-libqt5xml5, zlib1g (>= 1:1.1.4), libsecret-tools, ocqt51210-libqt5sql5-sqlite, ocqt51210-qtsvg5, ocqt51210-qttranslations5, ocqt51210-qtwayland5
Error:
ocqt51210-libqt5core5a : Hängt ab von: libicu70 (>= 70.1-1~) ist aber nicht installierbar
cortho
October 25, 2022, 11:16am
#2
Hi hamiller,
at a first glance it looks your repository is outdated. Make sure you are using the one for Ubuntu 22.04 at Install package owncloud-client
Still I think you won’t be happy since the ownCloud client is not working with wayland ATM, see Wayland support · Issue #8328 · owncloud/client · GitHub
So you’ll have to wait until this bug is fixed or run your Ubuntu without wayland.
repo looks good to me:
deb [arch=amd64 signed-by=/usr/share/keyrings/owncloud.gpg] https://download.owncloud.com/desktop/ownCloud/stable/latest/linux/Ubuntu_22.04/ /
however, in 22.10 you don’t have libicu70, but its successor 71…
Also I’ve been using owncloud client with Ubuntu 22.04 in wayland without issues (using the wayland integrated x11 fallback)
fmoc
October 25, 2022, 11:51am
#4
Apparently, you are using a repository for a different release. This has never been and will never be supported. We are working on adding the release and making a new build. However we have different top priorities right now, so this may take a few hours or days. I allocated a few minutes later this afternoon for this, though. I will post a comment here then to notify you.
(@cortho you may have got this wrong, @hamiller is using 22.10, you are suggesting the 22.04 repository.)
cortho
October 25, 2022, 12:25pm
#5
You are right, I was mistaken. thank you for the correction
Thanks for the clarification @fmoc . I was aware of the wrong release repo, but was in despair for a running client on 22.10…
So I will heavily welcome the new release, thanks again!
PS: “…daily/3.0/linux/Ubuntu_22.10” works so far - awesome!
fmoc
October 27, 2022, 12:56pm
#7
Took a bit longer than anticipated, but the new builds have just been deployed to the mirrors. You can now install packages for Ubuntu 22.10.
system
Closed
January 25, 2023, 12:57pm
#8
