Migrating from NextCloud to OwnCloud
Owncloud should sync my Documents folder
It says “Downgrading the folder from version 3.7.4 to 3.2.1 is not supported”
  1. Install OwnCloud
  2. Remove OwnCloud
  3. Install NextCloud
  4. Remove NextCloud because too buggy
  5. Install OwnCloud again
Operating system: Centos 7
Web server: LiteSpeed
PHP version: 7.4
ownCloud version: latest
Client version: 3.2.1
Operating system: Windows 10 x64
OS language: English
Installation path of client: 'C:\Program Files\ownCloud'
Option 1
Restore older backup config file:
Configuration File :: ownCloud Documentation
Option 2
You could try with the daily 4.0 pre-release builds:
4.0 | download.owncloud.com
4.0-beta1 expected in ~2 weeks.
