Migrating owncloud from VMWare 5.5 to 6.5
I have migrated owncloud from Hyper-V to VMware ESXi 5.5 server with no issues other than having to recreate the network adapter. I am now trying to migrate it to ESXi 6.5. The migration seem to succeed but could not connect to server via the web link? I was able to ping various computers but web link just lists generic 500 Internal Error. Has anyone done a migration like this before and know how I can troubleshoot.
Here is some information. I have inherited the server so I am not well versed on Ubuntu or OwnCloud:
  1. It is a OwnCloud 8.2.7 server
  2. Ubuntu is 14.05
Let me know if any other details will help to troubleshoot. I did the migration while the server was online. Another option would be to install a new Owncloud server and migrate data. If someone can give me the steps to do that it may be faster than migrating.
Any help would be appreciated…
Server Configuration
OS: Ubuntu 14.04.5
Web Server: Apache(Best guess)
Database: ??
PHP Version: php5 (Guess)
Owncloud version: 8.2.7
in /var/www/html have 3 folders owncloud owncloud2 owncloud3 (Not sure Why)
As far as I know, the update of the VM shouldn’t cause problems for ownCloud as long as ownCloud can be accessed normally. If it’s an external link, maybe you can’t access because the DNS or ip address doesn’t match any longer with the VM
First of all, check and understand your setup. Under normal circumstances, you should have more than one ownCloud directory in the server. If you have more, check the configuration and the data directories of all of them in order to check if they share both directories.
If they don’t share the directories, I guess they’re different installations. You should be able to remove the installations that aren’t in use.
If they share the directories, all of the installations might share the same data, but the code running could be different. It’s usually fine as temporary measure, but DB structure might change between versions, so always have a backup of the DB just in case.
Once you’ve figure out what installation are you using, we’ll need the logs (the owncloud.log file is usually located in the owncloud’s data directory)
Note that you should consider to update the ownCloud’s installation to a newer one because 8.2.x is no longer maintained.
