Migration to 10.4.0.4
hello everyone
I have the following problem.
After migrating to version 10.4.0.4, now I can’t manage users, see folders or buttons that do nothing.
PHP version is 7.2 (last change I made)
Owncloud is hosted on a hosting service
Operating system: Hosting (Linux)
Web server: Apache 2.4.43
Database: MySQL 5.6.47
PHP version: 7.3
Updated from an older ownCloud or fresh install: Updated from an older ownCloud
Where did you install ownCloud from: 10.1
Login as admin user into your ownCloud and access http://example.com/index.php/settings/integrity/failed: It is empty, it shows nothing
Console:
Content Security Policy: La configuración de la página bloqueó la carga de un recurso en inline (“script-src”). onloadwff.js:71:798525
JQMIGRATE: Migrate is installed, version 1.4.0 jquery-migrate.min.js:2:552
El diseño se forzó antes de que la página se cargara completamente. Si las hojas de estilo aún no están cargadas, esto puede causar un destello de contenido sin estilo. jquery.js:9000:14
Deprecation warning: tipsy is deprecated. Use tooltip instead. js.js:2311:10
ReferenceError: oc_updateState is not defined
