Missing audio.svg file?
  1. Upload some music file
  2. show the content of this dir on the web ui
  3. See this error in the logfile
No errors
{“reqId”:“12C275DC-764A-464B-B05C-943403B08C0D”,“level”:3,“time”:“2019-10-16T17:20:43+02:00”,“remoteAddr”:“SOMEIP”,“user”:“SOMEUSER”,“app”:“PHP”,“method”:“GET”,“url”:“/owncloud/remote.php/dav/files/SOMEUSER/CVJM/Musik/Frieden%20Finden%20-%20Lied%20zur%20Jahreslosung%202019.mp3?y=120&preview=1&x=120&c=%229620104c392b02dab778db75845283a9%22&a=1”,“message”:“imagecreatefromstring(): Empty string or invalid image at /var/www/html/owncloud/lib/private/legacy/image.php#573”}
{“reqId”:“E5C8FB2F-9DA1-465D-8D58-9A97E359AA91”,“level”:3,“time”:“2019-10-16T17:20:44+02:00”,“remoteAddr”:“SOMEIP”,“user”:“SOMEUSER”,“app”:“PHP”,“method”:“GET”,“url”:“/owncloud/remote.php/dav/files/SOMEUSER/CVJM/Musik/God%20-%20of.mp3?y=120&preview=1&x=120&c=%225639b4ca3ca3ee757907d3956eb4881b%22&a=1”,“message”:“file_get_contents(/media/owncloud/data/SOMEUSER/files/var/www/html/owncloud/core/img/filetypes/audio.svg): failed to open stream: No such file or directory at /var/www/html/owncloud/lib/private/Files/Storage/Local.php#227”}
{“reqId”:“E5C8FB2F-9DA1-465D-8D58-9A97E359AA91”,“level”:3,“time”:“2019-10-16T17:20:44+02:00”,“remoteAddr”:“SOMEIP”,“user”:“SOMEUSER”,“app”:“PHP”,“method”:“GET”,“url”:“/owncloud/remote.php/dav/files/SOMEUSER/CVJM/Musik/God%20-%20of.mp3?y=120&preview=1&x=120&c=%225639b4ca3ca3ee757907d3956eb4881b%22&a=1”,“message”:“imagecreatefromstring(): Empty string or invalid image at /var/www/html/owncloud/lib/private/legacy/image.php#573”}
Raspbian Stretch
Apache2
MariaDB
PHP7.0
10.2.1
Updated from older
Enabled:
  • activity: 2.5.0
  • audioplayer: 2.8.4
  • brute_force_protection: 1.0.1
  • calendar: 1.6.3
  • comments: 0.3.0
  • configreport: 0.2.0
  • contacts: 1.5.5
  • dav: 0.4.0
  • extract: 1.2.0
  • federatedfilesharing: 0.4.0
  • federation: 0.1.0
  • files: 1.5.2
  • files_clipboard: 0.7.1
  • files_external: 0.7.1
  • files_mediaviewer: 1.0.0
  • files_pdfviewer: 0.11.0
  • files_sharing: 0.11.0
  • files_texteditor: 2.3.0
  • files_trashbin: 0.9.1
  • files_versions: 1.3.0
  • firstrunwizard: 1.2.0
  • market: 0.5.0
  • metadata: 0.9.0
  • notifications: 0.5.0
  • password_policy: 2.0.2
  • provisioning_api: 0.5.0
  • systemtags: 0.3.0
  • templateeditor: 0.4.0
  • theme-blindbaucloud: 2.0.0
  • updatenotification: 0.2.1
    Disabled:
  • encryption
  • external
  • files_videoplayer
  • user_external
no
this looks very strange to me:
Could it be possible that you have moved the data directory from /var/www/html/owncloud/data to /media/owncloud/data/ in the past without following the documentation on how to update the database entries?
Ok, i just had the idea to search for this error:
in the ownCloud bugtracker to see if this was reported to the ownCloud team and it looks to me that indeed something was already reported to them:
I move the data dir after installing owncloud. So this is two years ago.
So this look like the issue from individual-it but the oc version is 10.2.1
