Hello, my log contains a lot of these:
{“reqId”:“3fc84600-0e0e-4add-a455-051e0cadce5b”,“level”:3,“time”:“2018-10-02T20:27:47+02:00”,“remoteAddr”:“192.168.2.1”,“user”:“raspy”,“app”:“PHP”,“method”:“PROPFIND”,“url”:"/owncloud/remote.php/dav/files/raspy/",“message”:“Module ‘apcu’ already loaded at Unknown#0”}
Is this supposed to happen?
Server version: Apache/2.4.25 (Raspbian)
mysql Ver 15.1 Distrib 10.1.23-MariaDB, for debian-linux-gnueabihf (armv7l) using readline 5.2
PHP 7.0.30-0+deb9u1
ownCloud 10.0.10 (stable)
fresh install
https://download.owncloud.org/download/repositories/10.0/Debian_9.0/
<?php
$CONFIG = array (
'updatechecker' => false,
'instanceid' => '***REMOVED SENSITIVE VALUE***',
'passwordsalt' => '***REMOVED SENSITIVE VALUE***',
'secret' => '***REMOVED SENSITIVE VALUE***',
'trusted_domains' =>
array (
0 => 'myhostname',
'datadirectory' => '/var/local/owncloud_data',
'overwrite.cli.url' => 'https://myhostname/owncloud',
'htaccess.RewriteBase' => '/owncloud',
'dbtype' => 'mysql',
'version' => '10.0.10.4',
'dbname' => 'owncloud',
'dbhost' => 'localhost',
'dbtableprefix' => 'oc_',
'dbuser' => 'Admin',
'dbpassword' => '***REMOVED SENSITIVE VALUE***',
'logtimezone' => 'Europe/Berlin',
'installed' => true,
'maintenance' => false,
'enable_previews' => false,
'memcache.locking' => '\\OC\\Memcache\\APCu',
'updater.secret' => '***REMOVED SENSITIVE VALUE***',
'loglevel' => 2,
- configreport: 0.1.1
- dav: 0.4.0
- encryption: 1.3.1
- federatedfilesharing: 0.3.1
- files: 1.5.1
- files_external: 0.7.1
- files_sharing: 0.11.0
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- firstrunwizard: 1.1
- market: 0.2.5
- notifications: 0.3.5
- updatenotification: 0.2.1
Are you using external storage, if yes which one:
no
Are you using encryption:
yes
Are you using an external user-backend, if yes which one:
I don’t think so.
Firefox 62.0.2 (64-bit)
Windows 10
{"reqId":"0469eeae-6773-4e08-ae42-d8a3c3b39e29","level":3,"time":"2018-10-03T13:51:52+02:00","remoteAddr":"192.168.1.4","user":"--","app":"PHP","method":"GET","url":"\/owncloud\/status.php","message":"Module 'apcu' already loaded at Unknown#0"}
{"reqId":"6ea74006-e2ea-4827-b680-6acf520ecae3","level":3,"time":"2018-10-03T13:51:54+02:00","remoteAddr":"192.168.1.4","user":"User1","app":"PHP","method":"GET","url":"\/owncloud\/ocs\/v1.php\/config?format=json","message":"Module 'apcu' already loaded at Unknown#0"}
{"reqId":"e68d6773-1c3d-49c5-8eea-5267d3322b39","level":3,"time":"2018-10-03T13:52:23+02:00","remoteAddr":"192.168.1.4","user":"User1","app":"PHP","method":"PROPFIND","url":"\/owncloud\/remote.php\/dav\/files\/User1\/","message":"Module 'apcu' already loaded at Unknown#0"}
{"reqId":"3dae9c31-e6ff-46be-8abc-884072880068","level":3,"time":"2018-10-03T13:52:49+02:00","remoteAddr":"192.168.1.4","user":"User1","app":"PHP","method":"PROPFIND","url":"\/owncloud\/remote.php\/dav\/files\/User1\/","message":"Module 'apcu' already loaded at Unknown#0"}
{"reqId":"08b5349f-d49a-4227-a4d5-e058c54cff3a","level":3,"time":"2018-10-03T13:53:19+02:00","remoteAddr":"192.168.1.4","user":"User1","app":"PHP","method":"PROPFIND","url":"\/owncloud\/remote.php\/dav\/files\/User1\/","message":"Module 'apcu' already loaded at Unknown#0"}
{"reqId":"083808e0-ada1-4478-8be1-15c71e798dc8","level":3,"time":"2018-10-03T13:53:49+02:00","remoteAddr":"192.168.1.4","user":"User1","app":"PHP","method":"PROPFIND","url":"\/owncloud\/remote.php\/dav\/files\/User1\/","message":"Module 'apcu' already loaded at Unknown#0"}
{"reqId":"121cff83-6b6e-4892-b994-4ec54a1059ee","level":3,"time":"2018-10-03T13:54:19+02:00","remoteAddr":"192.168.1.4","user":"User1","app":"PHP","method":"PROPFIND","url":"\/owncloud\/remote.php\/dav\/files\/User1\/","message":"Module 'apcu' already loaded at Unknown#0"}
{"reqId":"4b0bcec6-24c7-4596-a37f-d9c2cc5878ca","level":3,"time":"2018-10-03T14:24:19+02:00","remoteAddr":"192.168.1.4","user":"User1","app":"PHP","method":"PROPFIND","url":"\/owncloud\/remote.php\/dav\/files\/User1\/","message":"Module 'apcu' already loaded at Unknown#0"}
{"reqId":"Ppias2Vi8Hwc0vnQOevc","level":3,"time":"2018-10-03T14:24:30+02:00","remoteAddr":"192.168.1.4","user":"Admin","app":"PHP","method":"POST","url":"\/owncloud\/login","message":"Module 'apcu' already loaded at Unknown#0"}
{"reqId":"y07x8H0ueSa2n6LdHglq","level":3,"time":"2018-10-03T14:24:31+02:00","remoteAddr":"192.168.1.4","user":"Admin","app":"PHP","method":"GET","url":"\/owncloud\/core\/js\/oc.js?v=8232ddba4e98d8a686382a7a48209433","message":"Module 'apcu' already loaded at Unknown#0"}
{"reqId":"lJqrJnZXYliQh0hk38eR","level":3,"time":"2018-10-03T14:24:37+02:00","remoteAddr":"192.168.1.4","user":"Admin","app":"PHP","method":"GET","url":"\/owncloud\/avatar\/Admin\/145","message":"Module 'apcu' already loaded at Unknown#0"}
I do not know where to find it.
