ownCloud is great, congrats!
Please, why isn’t there a move option in the web interface, so I can move files/folders without reuploading them?
Already there:
You can move files and folders by dragging and dropping them into any directory.
Wow, great!! Thanks and sorry, had not noticed. Will check docs next time ![]()
Still, perhaps a good idea, just for usability, if not too hard, maybe there could be a Move inside menu where there’s rename, delete, etc.
Thanks!
if you have improvement suggestions / feature wishes its the best to post that at the github bugtracker [1] as feature requests are rarely picked up / commented in here.
[1] GitHub · Where software is built
Edit
There is an existing feature request:
Thanks you for your help.
Solution is dead link. can someone please update?
It is essentially the sentence quoted …
Unusable. I have created a directory, it sorts at the top of my so far unsorted list of camera uploads. Then I tagged about 50 images some 1000 images down the list as the first bunch to move to a named subdirectory. So then I grab the images and when I hit the top of the screen I get a second-long animation of the list moving down. Then if I move the mouse again inside the top area of the screen, again I get the second long animation. I’m not looking forward to spending 20 minutes dragging those files to the directory at the top.
Sure. Workaround: do it commandline or first name the directory similar to the first filename.
For all the people that end up here via Google looking for a solution to a very basic problem:
Try the owncloud app as a workaround.
Moving files is possible with the android app. Just as you would expect. Don’t know about iOS. (Anybody any info on that?)
Sorry to say: Don’t get your hopes up!
This thread seems to be a dead end, as does the above github issue (which is going in circles as well).
That being said: would still choose owncloud over Drive and Dropbox any day. Thanks.
a second file-tree in the browser-app would be nice, like the file commander back in the days…
this would help to move folders wherever you want.
