Move from owncloud
Hello
At the moment I use owncloud version 9 on a Raspberry 3. In the owncloud the calendar app and the contacts app are running.
Now I would like to switch to a Windows 10 system. That means, I would like to install the current version of owncloud on a Windows 10 PC and take over the data (contacts, appointments, files) from the owncloud of the Raspberry.
Can someone explain to me how to do this without losing data.
I’m grateful for any help.
MfG
Andreas
Hello
But I could run owncloud in a VM, right?
if you want to move the rapsberry installation of ownCloud to a new Linux-VM running within your windows system then i think you probably could follow the documentation here:
https://doc.owncloud.org/server/administration_manual/maintenance/migrating.html
