I want to move my drive that has ownCloud 9.0.3 onto my other computer, call it B. We’ll call the current computer with ownCloud, A. Computer A and B have the same versions of Linux Mint Debian.
Does it seem reasonable to assume that I can do the following to get ownCloud working on computer B:
Install the same versions of apache2 and MySQL onto computer B
Make a backup of ownCloud data directory, config directory and MySQL database from computer A.
Install ownCloud 9.0.3 on computer B. Overwrite ownCloud data directory, config directory and MySQL database on computer B with the backup from computer A.
Hi, I was thinking about your response. So, can I just change the config file where it says:
‘trusted_domains’ =>
array (
0 => ‘localhost’,
1 => ‘’,
2 => ‘’,
Normally, you keep the hostname. But if you change the hostname, you have to add it to the trusted_domains (and you need to change it at all connected clients). To avoid a complete resync of data, you have to close the client and change the hostname in the config-file:
