1.There are two or three entries in contacts birthday calendar per person
2.There is a single contact which contains birthday information for each relevant person in contacts (there may be an entry for some people in multiple addressbooks though, but only one contains birthday information)
3. Addressbooks have been deleted and recreated for various reasons
One entry per person
Two or three entries per person, unable to delete the extra ones.
Operating system: Debian Jessie 8.7
Web server: Apache 2.4.10 (Debian)
Database: Mysql 14.14 Distrib 5.5.54
PHP version: 5.6.30-0+deb8u1
ownCloud version (see ownCloud admin page): 9.1.4 (stable)
Special configuration (external storage, external authentication, reverse proxy, server-side-encryption): None
Integrity status for oC9+
paste the results here.
I presume the entries get added each time a contact is found with a birthday. Once that addressbook is deleted, the entries aren’t removed, so adding and removing addressbooks leads to stale information. How can I remove the additional entries/refresh the contacts birthdays calendar?
