Multiply IMAP auth servers
  1. define 2 IMAP auth sections in config file
I expect to search auth account in all defined IMAP until found
Auth is don only with first IMAP entry ignoring second one
Operating system: Ubuntu
Web server: Apache
Database: mysql
ownCloud version: (see ownCloud admin page) 10.15.0
Updated from an older ownCloud or fresh install: update
Where did you install ownCloud from: official repo
I dont see anything in the IMAP authentication documentation that suggests that more than one IMAP server can be configured. Did you find something that suggests it is possible? Can you share it?
Have you tried this? This response is from perplexity Ai.
You can define multiple IMAP authentication sections in the config.php file for ownCloud. However, ownCloud’s behavior is such that it will only use the first IMAP backend defined for authentication, ignoring subsequent entries. This limitation makes it challenging to use multiple IMAP servers effectively for authentication purposes without additional customization.
Configuration Example
To define two IMAP authentication backends in the config.php file, you can use the following syntax:
'user_backends' => array(
    array(
        'class' => 'OC_User_IMAP',
        'arguments' => array('{imap.server1.com:993/imap/ssl}', 'example.com'),
    array(
        'arguments' => array('{imap.server2.com:993/imap/ssl}', 'example.org'),
Explanation
  • First Backend: Authenticates users against imap.server1.com and restricts logins to the domain example.com.
  • Second Backend: Authenticates users against imap.server2.com and restricts logins to the domain example.org.
Known Issues
  • The authentication process will only consider the first IMAP backend (imap.server1.com) and ignore the second one (imap.server2.com) due to how ownCloud handles multiple entries in the user_backends array[6].
Workaround
If you need to authenticate against multiple IMAP servers, consider these options:
  1. Custom Development:
    • Modify the external user authentication app (user_external) to support multiple IMAP backends properly. This requires programming skills and familiarity with PHP.
  2. Proxy IMAP Server:
    • Set up a proxy IMAP server that aggregates multiple IMAP servers into a single endpoint. This way, ownCloud only needs to authenticate against one server.
  3. Separate Instances:
    • Run separate ownCloud instances for each IMAP server if feasible.
  4. Log File Debugging:
    • Check owncloud/data/owncloud.log for insights into why subsequent backends are ignored[4].
If none of these solutions are suitable, you may need to consult with ownCloud developers or community forums for further assistance.
