- I use the SFTP option to add external storage with username password
external storage access
Connection fail
Operating system: Ubuntu Server 20.04 LTSR
Web server: Apache/2.4.41 (Ubuntu)
Database: 10.3.32-MariaDB-0ubuntu0.20.04.1 Ubuntu 20.04
PHP version: PHP 7.4.3 (cli)
ownCloud version: (see ownCloud admin page) 10.9.1.2
Updated from an older ownCloud or fresh install: 10.9.1.2
Where did you install ownCloud from: Documentation guide
Signing status (ownCloud 9.0 and above): no
config file
“system”: {
“trusted_domains”: [
“localhost”,
“192.168.100.72”
“datadirectory”: “/var/www/owncloud/data”,
“overwrite.cli.url”: “http://localhost”,
“dbtype”: “mysql”,
“version”: “10.9.1.2”,
“dbname”: “owncloud”,
“dbhost”: “localhost”,
“dbtableprefix”: “oc_”,
“mysql.utf8mb4”: true,
“allow_user_to_change_mail_address”: “”,
“logtimezone”: “UTC”,
“apps_paths”: [
“path”: “/var/www/owncloud/apps”,
“url”: “/apps”,
“writable”: false
“path”: “/var/www/owncloud/apps-external”,
“url”: “/apps-external”,
“writable”: true
“installed”: true,
“instanceid”: “ocr7t70bk517”,
“memcache.local”: “\OC\Memcache\APCu”,
“memcache.locking”: “\OC\Memcache\Redis”,
“redis”: {
“host”: “127.0.0.1”,
“port”: “6379”
nabled:
- activity:
- Version: 2.6.1
- comments:
- Version: 0.3.0
- configreport:
- Version: 0.2.0
- dav:
- Version: 0.7.0
- federatedfilesharing:
- Version: 0.5.0
- federation:
- Version: 0.1.0
- files:
- Version: 1.5.2
- files_external:
- Version: 0.8.0
- files_mediaviewer:
- Version: 1.0.5
- files_pdfviewer:
- Version: 1.0.1
- files_sharing:
- Version: 0.14.0
- files_texteditor:
- Version: 2.4.1
- Path: /var/www/owncloud/apps/files_texteditor
- files_trashbin:
- Version: 0.9.1
- files_versions:
- Version: 1.3.0
- firstrunwizard:
- Version: 1.2.0
- market:
- Version: 0.6.2
- notifications:
- Version: 0.5.4
- provisioning_api:
- Version: 0.5.0
- systemtags:
- Version: 0.3.0
- templateeditor:
- Version: 0.4.0
- Path: /var/www/owncloud/apps/templateeditor
- updatenotification:
- Version: 0.2.1
Disabled:
- admin_audit:
- Path: /var/www/owncloud/apps/admin_audit
- announcementcenter:
- Path: /var/www/owncloud/apps/announcementcenter
- customgroups:
- Path: /var/www/owncloud/apps/customgroups
- encryption:
- enterprise_key:
- Path: /var/www/owncloud/apps/enterprise_key
- external:
- files_antivirus:
- Path: /var/www/owncloud/apps/files_antivirus
- files_classifier:
- Path: /var/www/owncloud/apps/files_classifier
- files_external_dropbox:
- Path: /var/www/owncloud/apps/files_external_dropbox
- files_external_ftp:
- Path: /var/www/owncloud/apps/files_external_ftp
- files_ldap_home:
- Path: /var/www/owncloud/apps/files_ldap_home
- files_lifecycle:
- Path: /var/www/owncloud/apps/files_lifecycle
- firewall:
- Path: /var/www/owncloud/apps/firewall
- graphapi:
- Path: /var/www/owncloud/apps/graphapi
- guests:
- Path: /var/www/owncloud/apps/guests
- metrics:
- Path: /var/www/owncloud/apps/metrics
- oauth2:
- Path: /var/www/owncloud/apps/oauth2
- openidconnect:
- Path: /var/www/owncloud/apps/openidconnect
- password_policy:
- Path: /var/www/owncloud/apps/password_policy
- ransomware_protection:
- Path: /var/www/owncloud/apps/ransomware_protection
- sharepoint:
- Path: /var/www/owncloud/apps/sharepoint
- systemtags_management:
- Path: /var/www/owncloud/apps/systemtags_management
- theme-enterprise:
- Path: /var/www/owncloud/apps/theme-enterprise
- user_external:
- user_ldap:
- Path: /var/www/owncloud/apps/user_ldap
- user_shibboleth:
- Path: /var/www/owncloud/apps/user_shibboleth
- web:
- Path: /var/www/owncloud/apps/web
- windows_network_drive:
- Path: /var/www/owncloud/apps/windows_network_drive
- wopi:
- Path: /var/www/owncloud/apps/wopi
- workflow:
- Path: /var/www/owncloud/apps/workflow
Are you using external storage, if yes which one: yes i use qnap storage and started stftp and tested it’ no ploblem
Are you using encryption: No
Browser: Edge
Operating system: Window 10
Insert your websMon Feb 14 22:51:24.190695 2022] [mpm_prefork:notice] [pid 52143] AH00163: Apache/2.4.41 (Ubuntu) configured -- resuming normal operations
[Mon Feb 14 22:51:24.190753 2022] [core:notice] [pid 52143] AH00094: Command line: '/usr/sbin/apache2'
[Mon Feb 14 22:52:23.643002 2022] [mpm_prefork:notice] [pid 52143] AH00169: caught SIGTERM, shutting down
[Mon Feb 14 22:52:23.726666 2022] [mpm_prefork:notice] [pid 55948] AH00163: Apache/2.4.41 (Ubuntu) configured -- resuming normal operations
[Mon Feb 14 22:52:23.726747 2022] [core:notice] [pid 55948] AH00094: Command line: '/usr/sbin/apache2'
[Mon Feb 14 22:52:46.465122 2022] [mpm_prefork:notice] [pid 55948] AH00171: Graceful restart requested, doing restart
AH00112: Warning: DocumentRoot [/var/www/owncloud] does not exist
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1. Set the 'ServerName' directive globally to suppress this message
[Mon Feb 14 22:52:46.501299 2022] [mpm_prefork:notice] [pid 55948] AH00163: Apache/2.4.41 (Ubuntu) configured -- resuming normal operations
[Mon Feb 14 22:52:46.501314 2022] [core:notice] [pid 55948] AH00094: Command line: '/usr/sbin/apache2'
[Mon Feb 14 22:53:12.055058 2022] [mpm_prefork:notice] [pid 55948] AH00171: Graceful restart requested, doing restart
[Mon Feb 14 22:53:12.101983 2022] [mpm_prefork:notice] [pid 55948] AH00163: Apache/2.4.41 (Ubuntu) configured -- resuming normal operations
[Mon Feb 14 22:53:12.102010 2022] [core:notice] [pid 55948] AH00094: Command line: '/usr/sbin/apache2'
[Mon Feb 14 23:09:16.831372 2022] [mpm_prefork:notice] [pid 55948] AH00169: caught SIGTERM, shutting down
[Mon Feb 14 23:09:37.801384 2022] [mpm_prefork:notice] [pid 942] AH00163: Apache/2.4.41 (Ubuntu) configured -- resuming normal operations
[Mon Feb 14 23:09:37.801594 2022] [core:notice] [pid 942] AH00094: Command line: '/usr/sbin/apache2'
[Mon Feb 14 23:10:28.318712 2022] [authz_core:error] [pid 2077] [client 192.168.100.21:62869] AH01630: client denied by server configuration: /var/www/owncloud/data/htaccesstest.txt
[Mon Feb 14 23:22:35.284631 2022] [authz_core:error] [pid 1061] [client 192.168.100.21:63072] AH01630: client denied by server configuration: /var/www/owncloud/data/htaccesstest.txt
[Mon Feb 14 23:28:37.290002 2022] [authz_core:error] [pid 1063] [client 192.168.100.21:63207] AH01630: client denied by server configuration: /var/www/owncloud/data/htaccesstest.txt
erver log here
{"reqId":"BFBS8lEoPDCpLCuL7LUt","level":3,"time":"2022-02-15T07:08:49+00:00","remoteAddr":"192.168.100.21","user":"admin","app":"files_external","method":"GET","url":"\/index.php\/apps\/files_external\/globalstorages\/1?testOnly=true","message":"Exception: {\"Exception\":\"RuntimeException\",\"Message\":\"Invalid size\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/3rdparty\\\/phpseclib\\\/phpseclib\\\/phpseclib\\\/Net\\\/SSH2.php(3300): phpseclib3\\\\Net\\\\SSH2->read_remaining_bytes()\\n#1 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/3rdparty\\\/phpseclib\\\/phpseclib\\\/phpseclib\\\/Net\\\/SSH2.php(1536): phpseclib3\\\\Net\\\\SSH2->get_binary_packet()\\n#2 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/3rdparty\\\/phpseclib\\\/phpseclib\\\/phpseclib\\\/Net\\\/SSH2.php(1412): phpseclib3\\\\Net\\\\SSH2->key_exchange()\\n#3 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/3rdparty\\\/phpseclib\\\/phpseclib\\\/phpseclib\\\/Net\\\/SSH2.php(2159): phpseclib3\\\\Net\\\\SSH2->connect()\\n#4 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/3rdparty\\\/phpseclib\\\/phpseclib\\\/phpseclib\\\/Net\\\/SSH2.php(2137): phpseclib3\\\\Net\\\\SSH2->sublogin(*** sensitive parameters replaced ***)\\n#5 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/lib\\\/Lib\\\/Storage\\\/SFTP.php(140): phpseclib3\\\\Net\\\\SSH2->login(*** sensitive parameters replaced ***)\\n#6 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/lib\\\/Lib\\\/Storage\\\/SFTP.php(156): OCA\\\\Files_External\\\\Lib\\\\Storage\\\\SFTP->getConnection()\\n#7 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/Files\\\/External\\\/LegacyUtil.php(207): OCA\\\\Files_External\\\\Lib\\\\Storage\\\\SFTP->test()\\n#8 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/lib\\\/Controller\\\/StoragesController.php(254): OC\\\\Files\\\\External\\\\LegacyUtil::getBackendStatus()\\n#9 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/lib\\\/Controller\\\/StoragesController.php(303): OCA\\\\Files_External\\\\Controller\\\\StoragesController->updateStorageStatus()\\n#10 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/Http\\\/Dispatcher.php(170): OCA\\\\Files_External\\\\Controller\\\\StoragesController->show()\\n#11 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/Http\\\/Dispatcher.php(89): OC\\\\AppFramework\\\\Http\\\\Dispatcher->executeController()\\n#12 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/App.php(100): OC\\\\AppFramework\\\\Http\\\\Dispatcher->dispatch()\\n#13 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/Routing\\\/RouteActionHandler.php(47): OC\\\\AppFramework\\\\App::main()\\n#14 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/Route\\\/Router.php(344): OC\\\\AppFramework\\\\Routing\\\\RouteActionHandler->__invoke()\\n#15 \\\/var\\\/www\\\/owncloud\\\/lib\\\/base.php(927): OC\\\\Route\\\\Router->match()\\n#16 \\\/var\\\/www\\\/owncloud\\\/index.php(54): OC::handleRequest()\\n#17 {main}\",\"File\":\"\\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/3rdparty\\\/phpseclib\\\/phpseclib\\\/phpseclib\\\/Net\\\/SSH2.php\",\"Line\":3490}"}
{"reqId":"AFP7JuUkZ5deULfUVR8H","level":3,"time":"2022-02-15T07:08:49+00:00","remoteAddr":"192.168.100.21","user":"admin","app":"files_external","method":"GET","url":"\/index.php\/apps\/files_external\/globalstorages\/1?testOnly=true","message":"Exception: {\"Exception\":\"RuntimeException\",\"Message\":\"Invalid size\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/3rdparty\\\/phpseclib\\\/phpseclib\\\/phpseclib\\\/Net\\\/SSH2.php(3300): phpseclib3\\\\Net\\\\SSH2->read_remaining_bytes()\\n#1 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/3rdparty\\\/phpseclib\\\/phpseclib\\\/phpseclib\\\/Net\\\/SSH2.php(1536): phpseclib3\\\\Net\\\\SSH2->get_binary_packet()\\n#2 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/3rdparty\\\/phpseclib\\\/phpseclib\\\/phpseclib\\\/Net\\\/SSH2.php(1412): phpseclib3\\\\Net\\\\SSH2->key_exchange()\\n#3 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/3rdparty\\\/phpseclib\\\/phpseclib\\\/phpseclib\\\/Net\\\/SSH2.php(2159): phpseclib3\\\\Net\\\\SSH2->connect()\\n#4 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/3rdparty\\\/phpseclib\\\/phpseclib\\\/phpseclib\\\/Net\\\/SSH2.php(2137): phpseclib3\\\\Net\\\\SSH2->sublogin(*** sensitive parameters replaced ***)\\n#5 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/lib\\\/Lib\\\/Storage\\\/SFTP.php(140): phpseclib3\\\\Net\\\\SSH2->login(*** sensitive parameters replaced ***)\\n#6 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/lib\\\/Lib\\\/Storage\\\/SFTP.php(156): OCA\\\\Files_External\\\\Lib\\\\Storage\\\\SFTP->getConnection()\\n#7 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/Files\\\/External\\\/LegacyUtil.php(207): OCA\\\\Files_External\\\\Lib\\\\Storage\\\\SFTP->test()\\n#8 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/lib\\\/Controller\\\/StoragesController.php(254): OC\\\\Files\\\\External\\\\LegacyUtil::getBackendStatus()\\n#9 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/lib\\\/Controller\\\/StoragesController.php(303): OCA\\\\Files_External\\\\Controller\\\\StoragesController->updateStorageStatus()\\n#10 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/Http\\\/Dispatcher.php(170): OCA\\\\Files_External\\\\Controller\\\\StoragesController->show()\\n#11 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/Http\\\/Dispatcher.php(89): OC\\\\AppFramework\\\\Http\\\\Dispatcher->executeController()\\n#12 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/App.php(100): OC\\\\AppFramework\\\\Http\\\\Dispatcher->dispatch()\\n#13 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/Routing\\\/RouteActionHandler.php(47): OC\\\\AppFramework\\\\App::main()\\n#14 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/Route\\\/Router.php(344): OC\\\\AppFramework\\\\Routing\\\\RouteActionHandler->__invoke()\\n#15 \\\/var\\\/www\\\/owncloud\\\/lib\\\/base.php(927): OC\\\\Route\\\\Router->match()\\n#16 \\\/var\\\/www\\\/owncloud\\\/index.php(54): OC::handleRequest()\\n#17 {main}\",\"File\":\"\\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/3rdparty\\\/phpseclib\\\/phpseclib\\\/phpseclib\\\/Net\\\/SSH2.php\",\"Line\":3490}"}
{"reqId":"sWIV0WUAKWnPLNy47B3i","level":3,"time":"2022-02-15T07:10:14+00:00","remoteAddr":"192.168.100.21","user":"admin","app":"files_external","method":"GET","url":"\/index.php\/apps\/files_external\/globalstorages\/1?testOnly=true","message":"Exception: {\"Exception\":\"RuntimeException\",\"Message\":\"Invalid size\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/3rdparty\\\/phpseclib\\\/phpseclib\\\/phpseclib\\\/Net\\\/SSH2.php(3300): phpseclib3\\\\Net\\\\SSH2->read_remaining_bytes()\\n#1 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/3rdparty\\\/phpseclib\\\/phpseclib\\\/phpseclib\\\/Net\\\/SSH2.php(1536): phpseclib3\\\\Net\\\\SSH2->get_binary_packet()\\n#2 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/3rdparty\\\/phpseclib\\\/phpseclib\\\/phpseclib\\\/Net\\\/SSH2.php(1412): phpseclib3\\\\Net\\\\SSH2->key_exchange()\\n#3 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/3rdparty\\\/phpseclib\\\/phpseclib\\\/phpseclib\\\/Net\\\/SSH2.php(2159): phpseclib3\\\\Net\\\\SSH2->connect()\\n#4 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/3rdparty\\\/phpseclib\\\/phpseclib\\\/phpseclib\\\/Net\\\/SSH2.php(2137): phpseclib3\\\\Net\\\\SSH2->sublogin(*** sensitive parameters replaced ***)\\n#5 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/lib\\\/Lib\\\/Storage\\\/SFTP.php(140): phpseclib3\\\\Net\\\\SSH2->login(*** sensitive parameters replaced ***)\\n#6 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/lib\\\/Lib\\\/Storage\\\/SFTP.php(156): OCA\\\\Files_External\\\\Lib\\\\Storage\\\\SFTP->getConnection()\\n#7 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/Files\\\/External\\\/LegacyUtil.php(207): OCA\\\\Files_External\\\\Lib\\\\Storage\\\\SFTP->test()\\n#8 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/lib\\\/Controller\\\/StoragesController.php(254): OC\\\\Files\\\\External\\\\LegacyUtil::getBackendStatus()\\n#9 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/lib\\\/Controller\\\/StoragesController.php(303): OCA\\\\Files_External\\\\Controller\\\\StoragesController->updateStorageStatus()\\n#10 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/Http\\\/Dispatcher.php(170): OCA\\\\Files_External\\\\Controller\\\\StoragesController->show()\\n#11 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/Http\\\/Dispatcher.php(89): OC\\\\AppFramework\\\\Http\\\\Dispatcher->executeController()\\n#12 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/App.php(100): OC\\\\AppFramework\\\\Http\\\\Dispatcher->dispatch()\\n#13 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/Routing\\\/RouteActionHandler.php(47): OC\\\\AppFramework\\\\App::main()\\n#14 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/Route\\\/Router.php(344): OC\\\\AppFramework\\\\Routing\\\\RouteActionHandler->__invoke()\\n#15 \\\/var\\\/www\\\/owncloud\\\/lib\\\/base.php(927): OC\\\\Route\\\\Router->match()\\n#16 \\\/var\\\/www\\\/owncloud\\\/index.php(54): OC::handleRequest()\\n#17 {main}\",\"File\":\"\\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/3rdparty\\\/phpseclib\\\/phpseclib\\\/phpseclib\\\/Net\\\/SSH2.php\",\"Line\":3490}"}
{"reqId":"Td8qeZsY8fKrNRijVIek","level":3,"time":"2022-02-15T07:10:15+00:00","remoteAddr":"192.168.100.21","user":"admin","app":"files_external","method":"GET","url":"\/index.php\/apps\/files_external\/globalstorages\/1?testOnly=true","message":"Exception: {\"Exception\":\"RuntimeException\",\"Message\":\"Invalid size\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/3rdparty\\\/phpseclib\\\/phpseclib\\\/phpseclib\\\/Net\\\/SSH2.php(3300): phpseclib3\\\\Net\\\\SSH2->read_remaining_bytes()\\n#1 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/3rdparty\\\/phpseclib\\\/phpseclib\\\/phpseclib\\\/Net\\\/SSH2.php(1536): phpseclib3\\\\Net\\\\SSH2->get_binary_packet()\\n#2 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/3rdparty\\\/phpseclib\\\/phpseclib\\\/phpseclib\\\/Net\\\/SSH2.php(1412): phpseclib3\\\\Net\\\\SSH2->key_exchange()\\n#3 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/3rdparty\\\/phpseclib\\\/phpseclib\\\/phpseclib\\\/Net\\\/SSH2.php(2159): phpseclib3\\\\Net\\\\SSH2->connect()\\n#4 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/3rdparty\\\/phpseclib\\\/phpseclib\\\/phpseclib\\\/Net\\\/SSH2.php(2137): phpseclib3\\\\Net\\\\SSH2->sublogin(*** sensitive parameters replaced ***)\\n#5 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/lib\\\/Lib\\\/Storage\\\/SFTP.php(140): phpseclib3\\\\Net\\\\SSH2->login(*** sensitive parameters replaced ***)\\n#6 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/lib\\\/Lib\\\/Storage\\\/SFTP.php(156): OCA\\\\Files_External\\\\Lib\\\\Storage\\\\SFTP->getConnection()\\n#7 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/Files\\\/External\\\/LegacyUtil.php(207): OCA\\\\Files_External\\\\Lib\\\\Storage\\\\SFTP->test()\\n#8 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/lib\\\/Controller\\\/StoragesController.php(254): OC\\\\Files\\\\External\\\\LegacyUtil::getBackendStatus()\\n#9 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/lib\\\/Controller\\\/StoragesController.php(303): OCA\\\\Files_External\\\\Controller\\\\StoragesController->updateStorageStatus()\\n#10 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/Http\\\/Dispatcher.php(170): OCA\\\\Files_External\\\\Controller\\\\StoragesController->show()\\n#11 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/Http\\\/Dispatcher.php(89): OC\\\\AppFramework\\\\Http\\\\Dispatcher->executeController()\\n#12 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/App.php(100): OC\\\\AppFramework\\\\Http\\\\Dispatcher->dispatch()\\n#13 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/Routing\\\/RouteActionHandler.php(47): OC\\\\AppFramework\\\\App::main()\\n#14 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/Route\\\/Router.php(344): OC\\\\AppFramework\\\\Routing\\\\RouteActionHandler->__invoke()\\n#15 \\\/var\\\/www\\\/owncloud\\\/lib\\\/base.php(927): OC\\\\Route\\\\Router->match()\\n#16 \\\/var\\\/www\\\/owncloud\\\/index.php(54): OC::handleRequest()\\n#17 {main}\",\"File\":\"\\\/var\\\/www\\\/owncloud\\\/apps\\\/files_external\\\/3rdparty\\\/phpseclib\\\/phpseclib\\\/phpseclib\\\/Net\\\/SSH2.php\",\"Line\":3490}"}
