MySQL isolation level
Hi!
Is it mandatory to use “READ COMMITED”? Or is it OK to use (the default, and more stricter) “REPEATABLE READ” isolation level?
Our environment has a shared SQL server, that has multiple other databases besides the OwnCloud DB, so changing the isolation level would affect multiple different systems.
Bests,
Peter
yes, it is actually mandatory to use READ COMMITTED as ownCloud is using the TRANSACTION_READ_COMMITTED transaction isolation level.
This is even documented in the DB requirements: System Requirements :: ownCloud Documentation
You will see a warning in the Security & setup warnings section of the admin page in case this is not set: core/securitywarning.php at master · owncloud/core · GitHub
Hi Pako81!
Thank you for your reply!
We have a test installation of Owncloud, but regardless of what the isolation level is set to, we can not produce any error related to SQL on the “Security & setup warnings” site, not even when it was set to READ-UNCOMMITED.
Best regards,
Peter
