I’ve reinstalled my Proxmox server, and wanted to re instantiate my ownCloud docker container with a fresh MySQL server. At first I wanted to restore my old installation (that was running on mariadb), but I discovered that even a fresh ownlcoud install on an almost fresh MySQL server (with increased timeout server variables) wouldn’t start.
I’m getting the following the following docker log:
Creating volume folders...
Creating hook folders...
Waiting for MySQL...
wait-for-it: waiting 180 seconds for 172.18.10.1:3306
wait-for-it: 172.18.10.1:3306 is available after 0 seconds
Removing custom folder...
Linking custom folder...
Removing config folder...
Linking config folder...
Writing config file...
Fixing base perms...
Fixing data perms...
Fixing hook perms...
Installing server database...
Error while trying to create admin user: Failed to connect to the database: An exception occured in driver: SQLSTATE[HY000] [2006] MySQL server has gone away
In Docker, I created a 172.18.0.0/16 network called “fixnet”, which I specifically use to fix containers to static IPs. However, I don’t think is an issue, as I’ve verified that the docker container can indeed ping to the MySQL container. I’ve also verified that I can indeed use the custom owncloud user account to connect to the server, and manipulate the owncloud schema, by connecting using MySQL Workbench on my desktop machine.
- Fresh install mysql:latest of https://hub.docker.com/_/mysql, with empty data volume
- MySQL: Create owncloud schema and create custom user with full access on owncloud schema
- MySQL: Set several timeout variables 864000 (see them listed below)
- Fresh install owncloud:10.0 of https://hub.docker.com/_/owncloud, with empty data volume
- Docker container crashes out after attempting to create a fresh database on first boot
I expected the database tables to be created in the schema, and the installation process to proceed.
No tables were created, as the log errors out with “MySQL server has gone away error”
Operating system: Proxmox 6.2-4
Web server: n/a
Database: MySQL 8.0.20 Community Server
PHP version: n/a
ownCloud version: n/a
Updated from an older ownCloud or fresh install: n/a
Where did you install ownCloud from: docker hub
Signing status (ownCloud 9.0 and above): n/a
mysql.sh docker configuration
docker run --net fixnet --ip 172.18.10.1 --name mysql \
--mount type=bind,src=/path-to-nas/mysql/my.cnf,dst=/etc/my.cnf \
--mount type=bind,src=/path-to-nas/mysql/data,dst=/var/lib/mysql \
-e MYSQL_ROOT_PASSWORD=*** -p 3306:3306 -d mysql:latest
The following MySQL variables were changed to 864000 (10 days):
- mysqlx_connect_timeout
- mysqlx_interactive_timeout
- mysqlx_read_timeout
- mysqlx_wait_timeout
- mysqlx_write_timeout
- net_read_timeout
- net_write_timeout
- slave_net_timeout
- wait_timeout
owncloud.sh docker configuration
export OWNCLOUD_VERSION=10.0
export OWNCLOUD_DOMAIN=localhost
export ADMIN_USERNAME=***
export ADMIN_PASSWORD=***
export HTTP_PORT=8080
docker run -d \
--net fixnet \
--ip 172.18.10.2 \
--name owncloud \
-p ${HTTP_PORT}:8080 \
-e OWNCLOUD_DOMAIN=${OWNCLOUD_DOMAIN} \
-e OWNCLOUD_DB_TYPE=mysql \
-e OWNCLOUD_DB_NAME=owncloud \
-e OWNCLOUD_DB_USERNAME=owncloud \
-e OWNCLOUD_DB_PASSWORD=*** \
-e OWNCLOUD_DB_HOST=172.18.10.1 \
-e OWNCLOUD_ADMIN_USERNAME=${ADMIN_USERNAME} \
-e OWNCLOUD_ADMIN_PASSWORD=${ADMIN_PASSWORD} \
-e OWNCLOUD_REDIS_ENABLED=false \
-e OWNCLOUD_REDIS_HOST=redis \
-v /hyperpool/Backup/scripts/owncloud:/mnt/data:rw \
owncloud/server:${OWNCLOUD_VERSION}
<?php
$CONFIG = array (
'apps_paths' =>
array (
0 =>
array (
'url' => '/apps',
'writable' => false,
1 =>
array (
'path' => '/var/www/owncloud/custom',
'url' => '/custom',
'writable' => true,
'trusted_domains' =>
array (
0 => 'localhost',
'datadirectory' => '/mnt/data/files',
'dbtype' => 'mysql',
'dbhost' => '172.18.10.1:3306',
'dbname' => 'owncloud',
'dbuser' => 'owncloud',
'dbpassword' => '***',
'dbtableprefix' => 'oc_',
'log_type' => 'owncloud',
'supportedDatabases' =>
array (
0 => 'sqlite',
1 => 'mysql',
2 => 'pgsql',
'upgrade.disable-web' => true,
'default_language' => 'en',
'overwrite.cli.url' => 'http://localhost',
'htaccess.RewriteBase' => '/',
'logfile' => '/mnt/data/files/owncloud.log',
'loglevel' => 2,
'passwordsalt' => '***',
'secret' => '***',
'version' => '10.0.10.4',
Are you using external storage, if yes which one: n/a
Are you using encryption: no
Are you using an external user-backend, if yes which one: n/a
{"reqId":"701f1D63b56w2v4OEVgE","level":3,"time":"2020-06-01T11:14:19+00:00","remoteAddr":"","user":"--","app":"PHP","method":"--","url":"--","message":"PDO::__construct(): MySQL server has gone away at \/var\/www\/owncloud\/lib\/composer\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Driver\/PDOConnection.php#43"}
