I’m trying to setup ownCloud with AWS Aurora MySQL 5.7 database but I get:
Error Code: 1709. Index column size too large. The maximum column size is 767 bytes.
I’m deploying ownCloud to Kubernetes using Helm chart from https://github.com/helm/charts/tree/master/stable/owncloud
I created database with
CREATE DATABASE owncloud CHARACTER SET utf8mb4 COLLATE utf8mb4_bin;
Here is the failing query:
CREATE TABLE owncloud.oc_mimetypes (
`id` INT AUTO_INCREMENT NOT NULL,
`mimetype` VARCHAR(255) DEFAULT '' NOT NULL,
UNIQUE INDEX mimetype_id_index (`mimetype`),
PRIMARY KEY (`id`)
) ROW_FORMAT=COMPRESSED;
If I remove ROW_FORMAT option, it works fine.
My server config:
mysql> show variables like "%version%";
| Variable_name | Value |
| aurora_version | 2.03.1 |
| innodb_version | 5.7.12 |
| protocol_version | 10 |
| slave_type_conversions | |
| tls_version | TLSv1,TLSv1.1,TLSv1.2 |
| version | 5.7.12 |
| version_comment | MySQL Community Server (GPL) |
| version_compile_machine | x86_64 |
| version_compile_os | Linux |
mysql> show global variables like 'innodb_lar%';
| innodb_large_prefix | ON |
mysql> show global variables like 'innodb_file%';
| innodb_file_format | Barracuda |
| innodb_file_format_check | ON |
| innodb_file_format_max | Barracuda |
| innodb_file_per_table | ON |
Any idea?
