Nach Update ist der Kalender defekt
Hi
seit dem Update wird der Kalender nicht mehr dargestellt.
In dem Feld in dem normal der Monat steht ist nur {{dt | datepickerFilter:selectedView}} sichtbar.
In der Apps-Liste steht
Calendar 1.4.1
durch [object Object],[object Object],[object Object]
(AGPL-lizensiert)
Was kann ich hier tun?
P.S.
sudo -u www-data /var/www/owncloud/occ app:check-code calendar
App is compliant - awesome job!
Server-Konfiguration
Betriebssystem: Debian 8
Webserver-Typ: Apache
Datenbank-Typ: MySQL
PHP-Version: PHP 5.6.29-0
ownCloud-Version (siehe ownCloud Administrationsseite):9.1.3 (stable)
Von einer älteren ownCloud-Version aktualisiert oder neu installiert?: Updates seit version 6
{"reqId":"J3EFD9ZEXXDRG09YxhLe","remoteAddr":"","app":"cron","message":"Finished OCA\\Files_Versions\\BackgroundJob\\ExpireVersions job with ID 27","level":0,"time":"2016-12-27T19:15:02+00:00","method":"--","url":"--","user":"--"}
{"reqId":"J3EFD9ZEXXDRG09YxhLe","remoteAddr":"","app":"cron","message":"Run OCA\\Files\\BackgroundJob\\ScanFiles job with ID 44","level":0,"time":"2016-12-27T19:15:02+00:00","method":"--","url":"--","user":"--"}
{"reqId":"J3EFD9ZEXXDRG09YxhLe","remoteAddr":"","app":"OC\\Files\\Cache\\Scanner","message":"!!! Path '' is not accessible or present !!!","level":0,"time":"2016-12-27T19:15:02+00:00","method":"--","url":"--","user":"--"}
{"reqId":"J3EFD9ZEXXDRG09YxhLe","remoteAddr":"","app":"OC\\Files\\Cache\\Scanner","message":"!!! Path '' is not accessible or present !!!","level":0,"time":"2016-12-27T19:15:03+00:00","method":"--","url":"--","user":"--"}
{"reqId":"J3EFD9ZEXXDRG09YxhLe","remoteAddr":"","app":"cron","message":"Finished OCA\\Files\\BackgroundJob\\ScanFiles job with ID 44","level":0,"time":"2016-12-27T19:15:03+00:00","method":"--","url":"--","user":"--"}
{"reqId":"J3EFD9ZEXXDRG09YxhLe","remoteAddr":"","app":"cron","message":"Run OC\\BackgroundJob\\Legacy\\RegularJob job with ID 1","level":0,"time":"2016-12-27T19:15:03+00:00","method":"--","url":"--","user":"--"}
{"reqId":"J3EFD9ZEXXDRG09YxhLe","remoteAddr":"","app":"cron","message":"Finished OC\\BackgroundJob\\Legacy\\RegularJob job with ID 1","level":0,"time":"2016-12-27T19:15:03+00:00","method":"--","url":"--","user":"--"}
{"reqId":"J3EFD9ZEXXDRG09YxhLe","remoteAddr":"","app":"cron","message":"Run OC\\BackgroundJob\\Legacy\\RegularJob job with ID 30","level":0,"time":"2016-12-27T19:15:03+00:00","method":"--","url":"--","user":"--"}
{"reqId":"J3EFD9ZEXXDRG09YxhLe","remoteAddr":"","app":"cron","message":"Finished OC\\BackgroundJob\\Legacy\\RegularJob job with ID 30","level":0,"time":"2016-12-27T19:15:03+00:00","method":"--","url":"--","user":"--"}
{"reqId":"J3EFD9ZEXXDRG09YxhLe","remoteAddr":"","app":"cron","message":"Run OC\\BackgroundJob\\Legacy\\RegularJob job with ID 35","level":0,"time":"2016-12-27T19:15:03+00:00","method":"--","url":"--","user":"--"}
{"reqId":"J3EFD9ZEXXDRG09YxhLe","remoteAddr":"","app":"news","message":"Configuration value \"simplePieCacheDuration\" does not exist. Ignored value.","level":2,"time":"2016-12-27T19:15:03+00:00","method":"--","url":"--","user":"--"}
{"reqId":"J3EFD9ZEXXDRG09YxhLe","remoteAddr":"","app":"cron","message":"Finished OC\\BackgroundJob\\Legacy\\RegularJob job with ID 35","level":0,"time":"2016-12-27T19:15:03+00:00","method":"--","url":"--","user":"--"}
{"reqId":"J3EFD9ZEXXDRG09YxhLe","remoteAddr":"","app":"cron","message":"Run OCA\\Files\\BackgroundJob\\DeleteOrphanedItems job with ID 45","level":0,"time":"2016-12-27T19:15:03+00:00","method":"--","url":"--","user":"--"}
{"reqId":"J3EFD9ZEXXDRG09YxhLe","remoteAddr":"","app":"DeleteOrphanedItems","message":"0 orphaned system tag relations deleted","level":0,"time":"2016-12-27T19:15:04+00:00","method":"--","url":"--","user":"--"}
{"reqId":"J3EFD9ZEXXDRG09YxhLe","remoteAddr":"","app":"DeleteOrphanedItems","message":"0 orphaned user tag relations deleted","level":0,"time":"2016-12-27T19:15:04+00:00","method":"--","url":"--","user":"--"}
{"reqId":"J3EFD9ZEXXDRG09YxhLe","remoteAddr":"","app":"DeleteOrphanedItems","message":"0 orphaned comments deleted","level":0,"time":"2016-12-27T19:15:04+00:00","method":"--","url":"--","user":"--"}
{"reqId":"J3EFD9ZEXXDRG09YxhLe","remoteAddr":"","app":"DeleteOrphanedItems","message":"0 orphaned comment read marks deleted","level":0,"time":"2016-12-27T19:15:04+00:00","method":"--","url":"--","user":"--"}
{"reqId":"J3EFD9ZEXXDRG09YxhLe","remoteAddr":"","app":"cron","message":"Finished OCA\\Files\\BackgroundJob\\DeleteOrphanedItems job with ID 45","level":0,"time":"2016-12-27T19:15:04+00:00","method":"--","url":"--","user":"--"}
{"reqId":"J3EFD9ZEXXDRG09YxhLe","remoteAddr":"","app":"cron","message":"Run OCA\\Files\\BackgroundJob\\CleanupFileLocks job with ID 46","level":0,"time":"2016-12-27T19:15:04+00:00","method":"--","url":"--","user":"--"}
{"reqId":"J3EFD9ZEXXDRG09YxhLe","remoteAddr":"","app":"cron","message":"Finished OCA\\Files\\BackgroundJob\\CleanupFileLocks job with ID 46","level":0,"time":"2016-12-27T19:15:04+00:00","method":"--","url":"--","user":"--"}
{"reqId":"J3EFD9ZEXXDRG09YxhLe","remoteAddr":"","app":"cron","message":"Run OCA\\DAV\\CardDAV\\SyncJob job with ID 49","level":0,"time":"2016-12-27T19:15:04+00:00","method":"--","url":"--","user":"--"}
{"reqId":"J3EFD9ZEXXDRG09YxhLe","remoteAddr":"","app":"cron","message":"Finished OCA\\DAV\\CardDAV\\SyncJob job with ID 49","level":0,"time":"2016-12-27T19:15:04+00:00","method":"--","url":"--","user":"--"}
{"reqId":"J3EFD9ZEXXDRG09YxhLe","remoteAddr":"","app":"cron","message":"Run OCA\\Files_Trashbin\\BackgroundJob\\ExpireTrash job with ID 26","level":0,"time":"2016-12-27T19:15:04+00:00","method":"--","url":"--","user":"--"}
{"reqId":"J3EFD9ZEXXDRG09YxhLe","remoteAddr":"","app":"cron","message":"Finished OCA\\Files_Trashbin\\BackgroundJob\\ExpireTrash job with ID 26","level":0,"time":"2016-12-27T19:15:04+00:00","method":"--","url":"--","user":"--"}
{"reqId":"J3EFD9ZEXXDRG09YxhLe","remoteAddr":"","app":"cron","message":"Run OC\\Authentication\\Token\\DefaultTokenCleanupJob job with ID 54","level":0,"time":"2016-12-27T19:15:04+00:00","method":"--","url":"--","user":"--"}
{"reqId":"J3EFD9ZEXXDRG09YxhLe","remoteAddr":"","app":"no app in context","message":"Invalidating tokens older than 2016-12-26T19:15:04+00:00","level":1,"time":"2016-12-27T19:15:04+00:00","method":"--","url":"--","user":"--"}
{"reqId":"J3EFD9ZEXXDRG09YxhLe","remoteAddr":"","app":"cron","message":"Finished OC\\Authentication\\Token\\DefaultTokenCleanupJob job with ID 54","level":0,"time":"2016-12-27T19:15:04+00:00","method":"--","url":"--","user":"--"}
{"reqId":"J3EFD9ZEXXDRG09YxhLe","remoteAddr":"","app":"cron","message":"Run OCA\\UpdateNotification\\Notification\\BackgroundJob job with ID 55","level":0,"time":"2016-12-27T19:15:04+00:00","method":"--","url":"--","user":"--"}
{"reqId":"J3EFD9ZEXXDRG09YxhLe","remoteAddr":"","app":"cron","message":"Finished OCA\\UpdateNotification\\Notification\\BackgroundJob job with ID 55","level":0,"time":"2016-12-27T19:15:04+00:00","method":"--","url":"--","user":"--"}
{"reqId":"v9B0vdrbVZoVCDhe1UOl","remoteAddr":"188.195.105.129","app":"news","message":"Configuration value \"simplePieCacheDuration\" does not exist. Ignored value.","level":2,"time":"2016-12-27T19:16:34+00:00","method":"GET","url":"\/owncloud\/settings\/admin","user"
Integrity status fĂĽr oC9+
Habe das gleiche Problem seit dem Update. Einen Kalender kann ich nicht mehr erstellen und die bereits vorhanden werden nicht angezeigt.
Meine Konfiguration:
Webserver-Typ: Nginx
Datenbank-Typ: SQLite
ownCloud-Version:9.1.2 (stable)
Von einer älteren ownCloud-Version aktualisiert oder neu installiert?: Updates seit Version 9.0
Diese Problem hier?
Hallo
ja genau das wars. Danke
Allerdings hatte ich nach {{dt | datepickerFilter:selectedView}} gesucht.
Ich frage mich warum ich nichts gefunden habe…
Moin,
leider verstehe ich dei Lösung nicht bzw. sie funktioniert bei mir nicht. Noch jemand eine andere Idee? Oder - falls ich zu blöd bin, die englische Lösung zu verstehen - gibt es irgendwo eine deutsche Zusammenfassung?
Es scheint nicht für alle zu klappen. Im nextcloud-fork gibt es ein paar Fixes, die müsste man eigentlich nach ownCloud zurückportieren (require sharingAPI to create new shares by georgehrke · Pull Request #215 · nextcloud/calendar · GitHub). @felixheidecke
Der Fehler ist gelöst!
Man muss die App “Sharing Files” aktivieren, ob ich sie manuell deaktiviert hatte oder sie durch ein Update ausgeschaltet wurde, kann ich nicht mehr nachvollziehen.
Auf jeden Fall läuft es wieder!
Danke fĂĽr die UnterstĂĽtzungen!
Das war auch bei mir ein Teil der Lösung.
Zusätzlich muss man unter Administrator „Apps die Benutzung der Share-API erlauben“ einschalten. (ich hatte dies selbst deaktiviert…)
Danke! :slight_smile:
Siehe Link von oben:
