Need a Hand with Collabora Integration
  1. Login as user to using browser
  2. Try to open document
Document should open to be edited.
Get message “Collabora Online unknown error: cURL error 35: error:0407006A:rsa routines:RSA_padding_check_PKCS1_type_1:block type is not 01
Please contact the “https://localhost:9980” administrator.”
Operating system: Linux 4.4.0-72-generic #93-Ubuntu SMP Fri Mar 31 14:07:41 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
Web server:Server version: Apache/2.4.18 (Ubuntu), Server built: 2016-07-14T12:32:26
Database: MariaDB
PHP version: 7.0
ownCloud version (see ownCloud admin page): ownCloud 9.1.4 (stable)
Special configuration (external storage, external authentication, reverse proxy, server-side-encryption): Nothing special
bunch of webdav stuff, not sure what's relevent.
Integrity status for oC9+
^^^ K, anyway… Uhm. It’s running on an AWS instance.
Hi, I was hoping to find someone out there with experience with Collabora Integration as well as maybe setting up the mail part of ownCloud. I can’t seem to get it running, probably some certificate issue (using self-signed now, and should work for my purposes?).
Not really looking for a how-to, although as a last resort that would be ok. More looking for an experienced expert I could pay for an hour or two of work fixing the kinks in my install. Thanks for any help! PM me or post, or tell me where to go look to hire?
Yes, most likely your certificate setup is somehow broken. I think giving support for this is outside of the scope of ownCloud so you might get some infos when throwing this message:
into your favorite search engine to find posts like:
http://openssl.6102.n7.nabble.com/RSA-verify-and-RSA-padding-check-PKCS1-type-1-block-type-is-not-01-error-td23363.html
http://openssl.6102.n7.nabble.com/block-type-is-not-01-td20966.html
