Hello, I allow myself to publish because I can not find any solution to my problem.
I have installed Owncloud to help him from Virtualbox with the Univention-App-owncloud-virtualbox. I do not touch anything even the IP which is like 192.168.1.XX
Then I manage to connect locally to this IP address.
Now my problem is that I can’t connect anywhere other than Local. If she that one would have a solution I would gladly accept it.
Thank you, I have followed what you sent me.
But I have the impression that my problem persists, when I send the URL of an Owncloud file to a person it does not work.
For example I put for the folder “Photo” Shared by public link then I copy and send the link “https://192.168.1.38/owncloud/f/7” and the person does not have access to it.
This is not a public link, this is the private link. Public links have an/s/ instead of the /f/
However you probably shared with an ownCloud internal user, that’s how you can give them access, nothing wrong with that. Just making sure we’re all using the same terminology
A private IP Address will never be routed through the internet. The other user has to be on your network either physically or via a VPN. Otherwise you need to give them your public IP address or set up a (dynamic) DNS and set up ownCloud to accept traffic on the other IP addresses and DNS names: ownCloud Documentation Overview
Thanks, I configured DNS and used no-ip to get a domain name or connect to it even outside.
My problem remains that when I create a public link it is “http://192.168.1.150/owncloud/s/7m4lFGKfR90BYmV”. So its always generates with an “S” and keeps my local IP and that I created “http://owncloudjude.hopto.org/” to connect me elsewhere than locally.
I just need to generate shares with links and I can’t do it.
Thanks for your help
