Need some sos with fail2ban trying to add trusted domains
can someone shed light what is wrong with this ?
today i have over 20 entires but my test does not find them 0 hits
added picture as host disappeared
[Definition]
failregex={.*“Trusted domain error. "')”}
ignoreregex =
Running tests
Use failregex filter file : myfilter, basedir: /etc/fail2ban
Use log file : /var/www/html/owncloud/data/owncloud.log
Use encoding : UTF-8
Results
Failregex: 0 total
Ignoreregex: 0 total
Date template hits:
|- [# of hits] date format
| [405] Year-Month-Day[T ]24hour:Minute:Second(?:.Microseconds)?(?:Zone offset)?
Lines: 405 lines, 0 ignored, 0 matched, 405 missed
[processed in 0.22 sec]
Missed line(s): too many to print. Use --print-all-missed to print all 405 lines
I know it is not answer of your question, but you can use this app https://marketplace.owncloud.com/apps/brute_force_protection for brute force protection instead of fail2ban. I hope it helps.
does this also banned the trusded domain attacks
if you define trusted domain attacks to me, I can answer your question. it simply bans any ip after defined failed attempts.
Didint expect that question
“reqId”:“pKcRS6b7H131udCNwvpW”,“level”:2,“time”:“2018-09-23T14:27:33-04:00”,“remoteAddr”:“190.109.165.85”,“user”:"–",“app”:“core”,“method”:“GET”,“url”:"/",“message”:“Trusted domain error. “190.109.165.85” tried to access using “removed :80” as host.”}
These are people trying to connect with ip since they are no good i want to banned them
Thanks for your help
i’m not sure but isn’t the configuration / setup of fail2ban not better placed in the fail2ban support forums?
