Need to Setup Different permissions on LDAP and local users
  1. i need to configure different permissions on a SMB/CIFS external folder for both on LDAP and local (owncloud) users
    2.i need the local (ownlcoud) users able to upload/edit/move and delete documents on a specific folder.
  2. also i need the LDAP users not to delete content on the same folder
cannot set up OC as i need
all users can upload/move/delete content.
Operating system: Linux owncloud 4.4.0-64-generic #85-Ubuntu SMP Mon Feb 20 11:50:30 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
PHP version: PHP 7.0.15-0ubuntu0.16.04.4 (cli) ( NTS )
ownCloud version (see ownCloud admin page): 9.1.3
Updated from an older ownCloud or fresh install: no
Integrity status for oC9+
paste the results here.
You could setup the share for a function user and then share with your LDAP users from this function users without delete rights. The CRUDS persmissions are only available for the sharing inside ownCloud.
