Hi guys
my fresh installation is always remind me:
Technical information
them.
Results
twofactor_totp
FILE_MISSING
vendor/khanamiryan/qrcode-detector-decoder/tests/QrReaderTest.php~
Raw output
Array
[twofactor_totp] => Array
[FILE_MISSING] => Array
[vendor/khanamiryan/qrcode-detector-decoder/tests/QrReaderTest.php~] => Array
[expected] => 05a20a084562bf6a61b9395635b2baa2fa0a3eb443d25027997cc3e83c71d5d1b3dfedd280149071db11121dc1ad30014e4b9778652808c2703b6d642b3b9a68
[current] =>
What have I to do to fix it?
thx
vincenzo
alfredb
November 20, 2020, 6:59pm
2
General recipe:
Extract the missing file from the package that you used for installation.
Copy that file to the place mentioned in your error message.
BTW, that topic was asked many times in the past. The search function might be your new friend.
Hi AlfredB!
thanks a lot…but…
both my installation and the original package do not have the missing file…
see attached the screenshot…
thanks
vincenzo
alfredb
November 21, 2020, 6:32am
4
What original package? From where?
BTW, Files ending with a ‘~’ character are backup files. So they never should belong to a package…
Consider to totally uninstall/remove the twofactor_totp app, then reinstall it from the market.
Hi Alfred
thx! Fixed!
I installed the TOTP without activating it… and no other message of integrity check failed!
have a great sunday
vincenzo
FKBOX
January 21, 2021, 10:48pm
6
Have the same problem after new install by repository. I don’t care anymore. I don’t use the admi to much.
There is no discription to solve the problem anywhere, but so what, cloud is working!
