Newbie Needs Help Securing Owncloud Classis (Docker 10.16.6)
I’m new to both Linux and Owncloud, but have lots of Windows experience. I’m learning as I go. Your patience is appreciated.
Operating system: Raspberry Pi OS (Debian Trixie 13)
Web server: Apache 2.4.52
Database: MariaDB 10.11
PHP version: 8.0
ownCloud version: (see ownCloud admin page) 10.16.6.0 Classic
Updated from an older ownCloud or fresh install: Fresh
Where did you install ownCloud from: Not sure, but I think it was from: Raspberry Pi ownCloud: Your Personal Cloud Storage - Pi My Life Up
Not yet.
No, not yet.
I don’t think so.
Browser: Brave 1.97.59
Operating system: Windows, MacOS
I am not experiencing any bugs or problems yet. I need advice on the best steps to secure my setup.
Total users: 3
No domain registered-using DDNS service on the router
I don’t want to forward any ports until I know I’ve reasonably secured this setup.
I’ve installed ufw for firewall purposes.
I read some of the wiki text on securing owncloud classic, but there’s so much info. I’m not familiar with. How do I know if should use a reverse proxy? Is there a good HOWTO somewhere for setting one up to work with Owncloud?
I’m not asking for handholding at every step, but I don’t even know where to start.
Thanks in advance for any help.
I cannot edit/resave my original post. It doesn’t allow using any links.
I created a config_report.json file, but I can’t upload it here. It contains 10 times the number of characters as the forum allows. It’s over 300K. Is that normal? Attachments seem to be limited to only graphic files. How do I post the report file?
I don’t do professional deployments nor security audits, so my advice is very limited.
First, keep your ownCloud installation up to date. ownCloud 10.x won’t be supported after the end of this year (roughly 2 months), so you’re encouraged to update your installation to 11.x (11.0.1 at the moment). You can still use your 10.x installation, but you won’t receive security updates, so updating to 11 is highly recommended.
From my point of view, it depends on how far you want to go with the deployment.
For a small installation, a basic deployment in a local network might be good enough if you don’t really need ubiquitous access. While you won’t access from outside your home (or wherever you have the server), you can still get the files you need in your mobile, or keep your photos in the mobile and upload what you want when you get home.
If you need access from anywhere, the installation will likely be on-the-wild, so of course you need to take security measures.
I’d say it depends on how hostile your environment is. Likely applicable to any security measure you want to include in your deployment.
In general, a reverse proxy can provide some features such as rate limiting and ip filtering, and it’s usually independent of whatever is behind the proxy.
Users will likely access to your ownCloud through the reverse proxy. If the reverse proxy is deployed in a different machine, a DDoS attack might take the reverse proxy down, but your server should be fine and you could interact with it, assuming you access through a different route (physical access to the machine, or through a SSH connection)
The drawback is that it’s another piece you have to maintain.
