I have owncloud sharing external storage (actually ZFS on OmniOS/napp-it shared via SMB) and I have a newer share in which I can’t see any files added in the past year or so.
I don’t think this is a permissions problem, because I can see these files via Windows with same credentials, and I also have another external storage share (inside the same ZFS filesystem, and using the same credentials/settings/etc) where newly added files appear with no issues.
I deleted and recreated the external storage folder/share in owncloud with no change. I have also reset the ACLs on the folders a few times, giving my own user full control, with no effect.
- Share a folder through SMB external storage (I had to do this using occ because the browser UI for doing it apparently doesn’t work, but that’s another story.)
- Create new text file in the shared folder via an SMB client, e.g. Windows, and observe that you can open, edit, and save it.
- Observe that the file does not appear in owncloud at all.
The newly created file should be viewable in the external storage in owncloud.
The newly created file is not visible in the browser or the app.
Operating system: Centos 7.9
Web server: nginx 1.20.1
Database: mysql
PHP version: 7.4
ownCloud version: 10.7.0.4
Where did you install ownCloud from: Centos package repository
https://gist.github.com/blandoon/63509d3b6d409f1eaf14d977aeab92cb#file-config_sanitized-php
https://gist.github.com/blandoon/63509d3b6d409f1eaf14d977aeab92cb#file-app-list
Are you using external storage, if yes which one: yes (SMB)
Are you using encryption: no
Browser: Firefox 89.0.2 (Windows 10)
https://gist.github.com/blandoon/63509d3b6d409f1eaf14d977aeab92cb#file-error-log
https://gist.github.com/blandoon/63509d3b6d409f1eaf14d977aeab92cb/raw/2ab7f93dff689a5ed2eaaca31f0e3389f0c67427/owncloud.log
