i tried to setup nginx today and it worked but now fastcgi/nginx doesnt load/show any css and js
here is my /etc/nginx/sites-enabled/owncloud
server {
listen 80;
listen [::]:80; listen 443 ssl;
root /var/www/html/owncloud;
index index.php index.html index.htm;
server_name domain domain;
ssl_certificate
/etc/nginx/ssl/nginx.crt;
ssl_certificate_key
/etc/nginx/ssl/nginx.key;
location / {
include /etc/nginx/mime.types;
rewrite ^ /index.php$uri;
I had exactly the same issue which made me almost insane. I have verified that all CSS and JS files are accessible in the browser first and they have been fine. I had that issue until I added nginx mime types right beneath the server_name. I can see you have mime types defined in your config but not sure if that is in right order. Let me share my config which works now as expected:
server {
server_name owncloud.mydomain.org;
listen 443 ssl; # managed by Certbot
ssl_certificate /etc/letsencrypt/live/owncloud.mydomain.org-0001/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/owncloud.mydomain.org-0001/privkey.pem; # managed by Certbot
include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
add_header X-Content-Type-Options nosniff always;
add_header X-Frame-Options "SAMEORIGIN" always;
add_header X-XSS-Protection "1; mode=block" always;
add_header X-Robots-Tag none always;
add_header X-Download-Options noopen always;
add_header X-Permitted-Cross-Domain-Policies none always;
root /var/www/owncloud;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
location = /.well-known/carddav {
return 301 $scheme://$host/remote.php/dav;
location = /.well-known/caldav {
# set max upload size
client_max_body_size 512M;
fastcgi_buffers 8 4K; # Please see note 1
fastcgi_ignore_headers X-Accel-Buffering; # Please see note 2
# Disable gzip to avoid the removal of the ETag header
# Enabling gzip would also make your server vulnerable to BREACH
# if no additional measures are done. See https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=773332
gzip off;
location / {
location ~ ^/(?:build|tests|config|lib|3rdparty|templates|data)/ {
return 404;
location ~ ^/(?:\.|autotest|occ|issue|indie|db_|console) {
return 404;
location ~ ^/(?:index|remote|public|cron|core/ajax/update|status|ocs/v[12]|updater/.+|ocs-provider/.+|ocm-provider/.+|core/templates/40[34])\.php(?:$|/) {
fastcgi_split_path_info ^(.+\.php)(/.*)$;
include fastcgi_params;
fastcgi_param SCRIPT_NAME $fastcgi_script_name; # necessary for owncloud to detect the contextroot https://github.com/owncloud/core/blob/v10.0.0/lib/private/AppFramework/Http/Request.php#L603
fastcgi_param PATH_INFO $fastcgi_path_info;
fastcgi_param HTTPS on;
fastcgi_param modHeadersAvailable true; #Avoid sending the security headers twice
fastcgi_param front_controller_active true;
fastcgi_read_timeout 180; # increase default timeout e.g. for long running carddav/ caldav syncs with 1000+ entries
fastcgi_pass unix:/run/php7.4-fpm.sock;
fastcgi_intercept_errors on;
fastcgi_request_buffering off; #Available since NGINX 1.7.11
location ~ ^/(?:updater|ocs-provider|ocm-provider)(?:$|/) {
try_files $uri $uri/ =404;
index index.php;
# Adding the cache control header for js and css files
# Make sure it is BELOW the PHP block
location ~ \.(?:css|js)$ {
try_files $uri /index.php$uri$is_args$args;
##add_header Cache-Control "max-age=15778463";
### Add headers to serve security related headers (It is intended to have those duplicated to the ones above)
### The always parameter ensures that the header is set for all responses, including internally generated error responses.
### Before enabling Strict-Transport-Security headers please read into this topic first.
### https://www.nginx.com/blog/http-strict-transport-security-hsts-and-nginx/
add_header Strict-Transport-Security "max-age=15552000; includeSubDomains; preload" always;
access_log on;
location ~ \.(?:svg|gif|png|html|ttf|woff|ico|jpg|jpeg|map|json)$ {
##add_header Cache-Control "public, max-age=7200";
# Optional: Don't log access to other assets
access_log on;
server {
if ($host = owncloud.mydomain.org) {
return 301 https://$host$request_uri;
} # managed by Certbot
Using nginx since years with multiple instances (domains) successfully. You may find some solutions at GitHub - mmattel/nginx-setup: nginx setup files You can drop the wordpress stuff as it is not relevant for your environment
