Hi there,
I’m trying to run owncloud on my vserver behind nginx, as I am already using nginx for other running applications. I mainly followed this tutorial, but there seems to something wrong with my configuration, as the files are served incorrectly.
logs
This is how it looks when I visit my.domain.com/owncloud:
(I already completed the registration step on a page, that looked just as broken as this one)
This is the tail of my php-fpm access log:
- - ***** 21/Apr/2018:11:07:01 +0200 "GET /owncloud/index.php" 200
- - ***** 21/Apr/2018:11:07:02 +0200 "GET /owncloud/index.php" 302
- - ***** 21/Apr/2018:11:07:02 +0200 "GET /owncloud/index.php" 200
configuration
general
- owncloud 10.0.7; ubuntu 16.04; nginx 1.10.3
- instance should be reachable at my.domain.com/owncloud
- owncloud files are located in /var/www/owncloud/
- www-user owns this folder and is also running php-fpm
nginx
Mostly copy+pase from https://doc.owncloud.org/server/10.0/admin_manual/installation/nginx_configuration.html
This snippet only concerns the owncloud location, and is included into my main config. Tell me if you need insight to this as well.
location ^~ /owncloud {
# set max upload size
client_max_body_size 512M;
fastcgi_buffers 8 4K; # Please see note 1
fastcgi_ignore_headers X-Accel-Buffering; # Please see note 2
# Disable gzip to avoid the removal of the ETag header
# Enabling gzip would also make your server vulnerable to BREACH
# if no additional measures are done. See https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=773332
gzip off;
# Uncomment if your server is build with the ngx_pagespeed module
# This module is currently not supported.
#pagespeed off;
error_page 403 /owncloud/core/templates/403.php;
error_page 404 /owncloud/core/templates/404.php;
location /owncloud {
rewrite ^ /owncloud/index.php$uri;
location ~ ^/owncloud/(?:build|tests|config|lib|3rdparty|templates|data)/ {
return 404;
location ~ ^/owncloud/(?:\.|autotest|occ|issue|indie|db_|console) {
return 404;
location ~ ^/owncloud/(?:index|remote|public|cron|core/ajax/update|status|ocs/v[12]|updater/.+|ocs-provider/.+|core/templates/40[34])\.php(?:$|/) {
include fastcgi_params;
fastcgi_split_path_info ^(.+\.php)(/.*)$;
fastcgi_param SCRIPT_FILENAME /var/www/$fastcgi_script_name;
fastcgi_param SCRIPT_NAME $fastcgi_script_name; # necessary for owncloud to detect the context root https://github.com/owncloud/core/blob/v10.0.0/lib/private/AppFramework/Http/Request.php#L603
fastcgi_param PATH_INFO $fastcgi_path_info;
fastcgi_param HTTPS on;
fastcgi_param modHeadersAvailable true; #Avoid sending the security headers twice
# EXPERIMENTAL: active the following if you need to get rid of the 'index.php' in the URLs
#fastcgi_param front_controller_active true;
fastcgi_read_timeout 180; # increase default timeout e.g. for long running carddav/ caldav syncs with 1000+ entries
fastcgi_pass unix:/run/php/php7.0-fpm.sock;
fastcgi_intercept_errors on;
fastcgi_request_buffering off; #Available since NGINX 1.7.11
location ~ ^/owncloud/(?:updater|ocs-provider)(?:$|/) {
try_files $uri $uri/ =404;
index index.php;
# Adding the cache control header for js and css files
# Make sure it is BELOW the PHP block
location ~ /owncloud/.*\.(?:css|js) {
try_files $uri /owncloud/index.php$uri$is_args$args;
add_header Cache-Control "max-age=15778463";
# Add headers to serve security related headers (It is intended to have those duplicated to the ones above)
# Before enabling Strict-Transport-Security headers please read into this topic first.
#add_header Strict-Transport-Security "max-age=15552000; includeSubDomains";
add_header X-Content-Type-Options nosniff;
add_header X-Frame-Options "SAMEORIGIN";
add_header X-XSS-Protection "1; mode=block";
add_header X-Robots-Tag none;
add_header X-Download-Options noopen;
add_header X-Permitted-Cross-Domain-Policies none;
# Optional: Don't log access to assets
access_log off;
location ~ /owncloud/.*\.(?:svg|gif|png|html|ttf|woff|ico|jpg|jpeg|map) {
add_header Cache-Control "public, max-age=7200";
# Optional: Don't log access to other assets
access_log off;
Thanks in advance ![]()
