No iPad-connection to a server with port-forwarding
I guess no bug but a problem
  1. working Debian based server withe ownCloud
  2. try to connectan iPad with my server to get contacts and calendars to the iPad
  3. Message “No connection”
iOS should connect to the oC-server for contacts and calendars
iOS is not possible to connect
Debian 9 beyond a router with port forwarding for ownCloud
Apache 2
mysql/mariadb
php7.3
ownCloud version:
10.4.0
Client
iOS version:
13.6
ownCloud app version:
v 1.3.2 - this app works fine, but ioS cannot connect to the ownCloud-Server
Device model:
iPad (7. gen.)
Tell us what could be improved:
I have a little server for contacts, calendars and filesharing. Several years it works fine using Windows- or Linux-devices, but now I get with my iPad the message “No connection” trying to bring contacts or calendars to its iOS. I found no helpfully hints in this channel though I looked many times for a thread.
For internet the server is connected beyond my router. There is an URL like “https://my-owncloud-server.de:1234” with port-forwarding managed by the router. Could the port or the port-forwarding block the iPad / iOS get connected to contacts and calendars?
Do you have hints or help? Thanks in advance
Maybe, I’ve got it.
Until now, I used the link builded in ownCloud for the calendar-address of my oC-server.
With the hints of this post https://central.owncloud.org/t/ios-12-calendar-ios-stock-via-caldav/15648/38?u=hellweg-116 I got a connection to my oC and the iPad-calendar filled up.
These two points seemed to be important:
The line with “Server” needs --> server-address.de/remote.php/dav/principals/users/my-username/
For Description, enter BHICAL
After that a littlebit back, forward and save - then it works. :slightly_smiling_face:
