- Run 9.1.8 happily on Debian 9
- Go to admin menu, follow upgrade instructions
- Things don’t go too well, lots of error messages
- Fix all errors (upgrade to PHP7, remove all apps)
- Finish upgrade manually with php occ upgrade
- Go to site, enter credentials
- Nothing happens :
- no logs in the web server or owncloud log files
- no log-in denied message (no wrong password, etc…)
- Browser follows through to login page
Successful login and files displayed.
Nothing beyond login screen.
Debian 9.11
Apache 2
MariaDB
10.1.1.1
Just updated from 9.1.8 through legit channels.
Initially : 9.1.0 tarball.
=> can’t login !!
"system": {
"instanceid": "oc765a449f83",
"trusted_domains": [
"xxxx.fr"
"datadirectory": "\/var\/www\/xxxx\/owncloud\/data",
"overwrite.cli.url": "https:\/\/xxxx.fr\/owncloud",
"dbtype": "mysql",
"version": "10.1.1.1",
"appstoreenabled": false,
"appstoreurl": "https:\/\/marketplace.owncloud.com\/api\/v0",
"apps_paths": [
"path": "\/var\/www\/xxxx\/owncloud\/apps",
"url": "\/apps",
"writable": false
"dbname": "owncloud",
"dbhost": "localhost",
"dbtableprefix": "oc_",
"installed": true,
"loglevel": 3,
"maintenance": false,
"trashbin_retention_obligation": "auto",
"appstore.experimental.enabled": true,
"theme": "",
"mail_smtpmode": "sendmail",
"mail_smtpport": "25",
"mail_smtpauthtype": "LOGIN",
"mail_smtpauth": 1,
"updater.secret": "***REMOVED SENSITIVE VALUE***"
Enabled:
- comments: 0.3.0
- configreport: 0.1.2
- dav: 0.4.0
- federatedfilesharing: 0.3.1
- federation: 0.1.0
- files: 1.5.2
- files_external: 0.7.1
- files_sharing: 0.11.0
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- files_videoplayer: 0.9.9
- notifications: 0.4.1
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- updatenotification: 0.2.1
Disabled:
- encryption
- external
- firstrunwizard
- market
- user_external
no
Are you using encryption:
no
no
Firefox
Windows 10
no logs
no log
