No marketplace connection: cURL error 7: Failed to connect to localhost port 1080: Connection refused
  1. In try to go to /app/market
  2. I get an error: No marketplace connection: cURL error 7: Failed to connect to localhost port 1080: Connection refused
I should be able to reach the app market and search/install applications.
I get an error saying that I am trying to connect to a local host marketplace.
Diet Pi Debian Distribution
Apache
MYSQL
7.3.29-1~deb10u1
ownCloud version:
ownCloud 10.8.0 (stable)
Updated from older version, but had the problem before.
Starting from the Diet Pi package, however, upgraded based on instructions from the official website.
    "system": {
        "trusted_domains": [
            "localhost",
            "sw-tiger.com",
            "192.168.0.186",
            "pi-jenkins",
            "192.168.0.36"
        "overwritehost": "sw-tiger.com",
        "proxy": "192.168.0.36",
        "overwriteprotocol": "https",
        "datadirectory": "\/mnt\/dietpi_userdata\/owncloud_data",
        "overwrite.cli.url": "http:\/\/localhost\/owncloud",
        "dbtype": "mysql",
        "version": "10.8.0.4",
        "filelocking.enabled": true,
        "redis": {
            "host": "\/run\/redis\/redis-server.sock",
            "port": 0
        "dbname": "owncloud",
        "dbhost": "localhost",
        "dbtableprefix": "oc_",
        "mysql.utf8mb4": true,
        "logtimezone": "UTC",
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "url": "\/apps-external",
                "writable": true
        "installed": true,
        "instanceid": "ochpczrmqnat",
        "maintenance": false,
        "mail_smtpmode": "smtp",
        "mail_smtpport": "465",
        "mail_smtpauthtype": "LOGIN",
        "mail_smtpauth": 1,
        "mail_smtpsecure": "ssl",
        "loglevel": 2
None
No
After seeing post: https://central.owncloud.org/t/this-server-has-no-working-internet-connection/10921
I understood that my Owncloud app tried to connect through a proxy, which was set to localhost.
After removing the proxy field in my config.php the error disappeared.
