- open webpage
- try to login
User should be able to login and view shared files
All users (except admin) are unable to login. Message: Wrong password. Reset it?
Admin can login, but user list is empty
In data folder, user subfolders do exist
LOCAL USERS AND GROUPS
*** SAME BEHAVIOUR ON DIFFERENT INSTALLATION - UPGRADE TO 10.5.0.10 ***
https://gist.github.com/shaesen/3cb6b54e7bf23722ef8b358cd79deb1e.js
https://gist.github.com/shaesen/aa157750f5165d91c8b0da42188b903e.js
