1.Upgrade to oC 9.1 using yum and have operational 9.1 system
2.Look for repo resources for oC 10 for CentOS 6
3.Found only repo resources for CentOS 7.
Should find repo resources for CentOS 6. It’s not dead yet.
No repo resources found for oC 10 on CentOS 6.
CentOS release 6.10 (Final) x86_64
httpd-2.2.15-69.el6.centos.x86_64
mysql-server-5.1.73-8.el6_8.x86_64
php-5.6.38-2.el6.remi.x86_64
owncloud-files-9.1.8-1.1.noarch
Updated from 7.0 -> 8.0 -> 8.1 -> 8.2 -> 9.0 -> 9.1 all within the last two weeks with a fair amount of abusive language.
software.opensuse.org and then download.owncloud.org, all using yum.
```N/A
‘admin’ -> ‘Generate Config Report’ -> ‘Download ownCloud config report’
“system”: {
“instanceid”: “ocb5cb6rxe9o”,
“trusted_domains”: [
“foo.mydomain.com”
“datadirectory”: “/var/www/html/owncloud/data”,
“overwrite.cli.url”: “http://foo.mydomain.com/owncloud”,
“dbtype”: “mysql”,
“version”: “9.1.8.2”,
“dbname”: “owncloud”,
“dbhost”: “localhost”,
“dbtableprefix”: “oc_”,
“installed”: true,
“mail_smtpmode”: “smtp”,
“mail_domain”: “foo.mydomain.com”,
“mail_from_address”: “root”,
“theme”: “”,
“loglevel”: 2,
“maintenance”: false,
“updatechecker”: false,
“trashbin_retention_obligation”: “auto”
`Enabled:
- activity: 2.3.2
- calendar: 1.6.0
- comments: 0.3.0
- configreport: 0.1.1
- contacts: 1.5.4
- dav: 0.2.7
- federatedfilesharing: 0.3.0
- federation: 0.1.0
- files: 1.5.1
- files_pdfviewer: 0.8.1
- files_sharing: 0.10.0
- files_texteditor: 2.1
- files_trashbin: 0.9.0
- files_versions: 1.3.0
- files_videoplayer: 0.9.8
- firstrunwizard: 1.1
- gallery: 15.0.0
- notifications: 0.3.0
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- templateeditor: 0.1
- updatenotification: 0.2.1
Disabled:
- encryption
- external
- files_antivirus
- files_external
- user_external
- user_ldap
**Are you using external storage, if yes which one:** no - local
**Are you using encryption:** no
**Are you using an external user-backend, if yes which one:** Webdav/...
### Client configuration
**Browser:**
firefox-60.3.0-1.el6.centos.x86_64
**Operating system:**
### Logs
#### Web server error log
```n/a
```n/a
```n/a
```n/a
#### Browser log
```n/a
```n/a
