I’m running Docker on Windows 10, and can see all 3 docker images running, but when I go to localhost:8082 (the port I specified to use in the .env and yaml files), all I get is “localhost didn’t send any data”
I’m assuming that the 200 after the GET statements above are the HTTP response code 200 OK, so the healthcheck seems to think that it’s up and running.
Any ideas what I can check to see where the problem is?
it would also be good if you would try to start a standard oC installation first, with the default values, to figure out if that works. Then you can start modifying and customising. This would be my approach anyway.
Hi Dmitry, sorry for the delay in replying - I managed to get some time away from the desk (woohoo!)
So I’ve tried what you suggested. I stopped the other container that was using port 8080 and started OwnCloud on the standard port, with the .env and docker-compose.yaml files also updated to only point to port 8080, and it works.
Given that the healthcheck seemed to be showing it was up when on port 8082, my guess is that it’s something to do with the web server being hard-wired to be on port 8080.
Whilst I could in theory change my other container to use a different port, there a lot of other things that point to that container so it would be a fair bit of work to reconfigure them all. Is there anyway you can think of to overome the issue?
