Hmm, works on my machine
How did you change ownership?
chown -R apache:apache /home/owncloud
yes
chown -R apache:apache owncloud
You really worked through the advises i gave you in post#2?
Yes i worked on all the advices you gave
i anyhow needs to make /home/owncloud/data active
What says owncloud.log?
I don’t think that this is related to our current problem.
BTW, copy/paste is sometimes better then screenshots.
ok
why is it showing data not writable even apache user is given and 777 permission too?
is any thing else that i am missing?
- Is apache really your httpd user?
- How is /home mounted?
No more ideas, unfortunately.
yes coz its working fine in /var/www/html forlder as they have apache ownership
No clue, it’s your system.
Hello Alfred,
My issue got solved
now its working fine in /home mount
It was due to PhpMyadmin
Great to hear that!
Maybe you could explain a little bit?
Finally please mark this thread as solved/Solution.
PhpMyadmin and Config file was getting clashed for giving correct permission, as both were giving permission to /home folder
so after disabling phpmyadmin, config file becomes only one to give correct path and permission.
so issue solved now
